You’ve signed the CLA, techAPJ. Thank you! This pull request is ready for review.
Screenshot?
— You are receiving this because you are subscribed to this thread. Reply to this email directly, view it on GitHub https://github.com/discourse/discourse/pull/7391#issuecomment-484050291, or mute the thread https://github.com/notifications/unsubscribe-auth/ABc7VUeG-3KJ_aPAnJ9YN2OHpw9uOSTZks5vhwo9gaJpZM4c03I5 .
Sorry, I added it in description after creating the PR so it mustn’t had been included in email. Attaching here again.
One minor nitpick: The text for the choices is light gray, which is meant for descriptions. Primary choices should be darker. cc @awesomerobot
I think should be all set if you just remove color: #777
when will this be ready for merge?
Currently wizard does not support a section of controls to be disabled, it either disables the whole step or none. So I’ll need to add a support for partially disabling controls. I expect it to be ready for merge early next week.
