FEATURE: bypass topic bump when disable_category_edit_notifications is enabled (#14754)
diff --git a/app/controllers/topics_controller.rb b/app/controllers/topics_controller.rb
index 099cc16..c2d98ae 100644
--- a/app/controllers/topics_controller.rb
+++ b/app/controllers/topics_controller.rb
@@ -387,8 +387,11 @@ class TopicsController < ApplicationController
     success = true
     if changes.length > 0
+      bypass_bump = changes[:category_id].present? && SiteSetting.disable_category_edit_notifications
       first_post = topic.ordered_posts.first
-      success = PostRevisor.new(first_post, topic).revise!(current_user, changes, validate_post: false)
+      success = PostRevisor.new(first_post, topic).revise!(current_user, changes, validate_post: false, bypass_bump: bypass_bump)
       if !success && topic.errors.blank?
         topic.errors.add(:base, :unable_to_update)
diff --git a/spec/requests/topics_controller_spec.rb b/spec/requests/topics_controller_spec.rb
index 2aa3b85..0171366 100644
--- a/spec/requests/topics_controller_spec.rb
+++ b/spec/requests/topics_controller_spec.rb
@@ -1358,6 +1358,37 @@ RSpec.describe TopicsController do
           expect(response.status).to eq(200)
+        context 'when using SiteSetting.disable_category_edit_notifications' do
+          it "doesn't bump the topic if the setting is enabled" do
+            SiteSetting.disable_category_edit_notifications = true
+            last_bumped_at = topic.bumped_at
+            expect(last_bumped_at).not_to be_nil
+            expect do
+              put "/t/#{topic.slug}/#{topic.id}.json", params: {
+                category_id: category.id
+            end.to change { topic.reload.category_id }.to(category.id)
+            expect(response.status).to eq(200)
+            expect(topic.reload.bumped_at).to eq_time(last_bumped_at)
+          end
+          it "bumps the topic if the setting is disabled" do
+            expect do
+            expect(topic.reload.bumped_at).not_to eq_time(last_bumped_at)
+          end
+        end
         describe "when first post is locked" do
           it "blocks non-staff from editing even if 'trusted_users_can_edit_others' is true" do
             SiteSetting.trusted_users_can_edit_others = true
GitHub sha: 92f4cdd3309d099e9a4f70a5016d138f2c07578e
This commit appears in #14754 which was approved by pmusaraj. It was merged by jmperez127.
