FEATURE - Category group moderators can (un)accept solutions, if enabled (#89)
index 0d727d1..a6462c7 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -472,6 +472,10 @@ SQL
       return true if is_staff?
       return true if current_user.trust_level >= SiteSetting.accept_all_solutions_trust_level
+      if respond_to? :can_perform_action_available_to_group_moderators?
+        return true if can_perform_action_available_to_group_moderators?(topic)
+      end
       topic.user_id == current_user.id && !topic.closed
diff --git a/spec/integration/solved_spec.rb b/spec/integration/solved_spec.rb
index e39a87e..f1cd055 100644
--- a/spec/integration/solved_spec.rb
+++ b/spec/integration/solved_spec.rb
@@ -148,4 +148,21 @@ RSpec.describe "Managing Posts solved status" do
       expect(payload["id"]).to eq(p1.id)
+  context 'group moderators' do
+    fab!(:group_user) { Fabricate(:group_user) }
+    let(:user_gm) { group_user.user }
+    let(:group) { group_user.group }
+    before do
+      SiteSetting.enable_category_group_moderation = true
+      p1.topic.category.update!(reviewable_by_group_id: group.id)
+      sign_in(user_gm)
+    end
+    it 'can accept a solution' do
+      post "/solution/accept.json", params: { id: p1.id }
+      expect(response.status).to eq(200)
+    end
+  end
GitHub sha: 6f1cf5a7
This commit appears in #89 which was approved by eviltrout. It was merged by jbrw.
