FEATURE: change default size for search recent posts
The site setting search_recent_posts_size controls the window of posts that we will search through before trying to search through the full index
If this number is too low then the search quality can suffer a lot as recent posts may dominate search. If the number is too high then performance will suffer.
This attempts to find a happy medium, 1 million posts will cover the majority of forums out there and should perform adequately.
diff --git a/config/site_settings.yml b/config/site_settings.yml
index d1b4641..9e48178 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1845,7 +1845,7 @@ search:
   search_tokenize_chinese_japanese_korean: false
   search_prefer_recent_posts: false
   search_recent_posts_size:
-    default: 100000
+    default: 1000000
     max: 10000000
   search_recent_regular_posts_offset_post_id:
     default: 0
GitHub sha: 580383df
