FEATURE: Create notification schedule to automatically set do not disturb time (PR #11665)
The new setting is in user -> preferences -> notifications
Here is a screenshot which shows how it works. By default every day is 8am - 5pm when first enabled.
GitHub
we have an i18n helper which would allow you to just do:
dayLabel: i18n("day", "user. notification_schedule.%@")
watchout will all this code, you compare val with string so I expect it’s a string, you compare it with a value which I expect is an ineteger, and then you add integer to it.
You should know that:
"30" + 10 // "3010"
I would try to make the type of val clearer here from the beginning.
I know it’s v1, but AM/PM support is locale dependant so we should have this hardcoded.
please do direct styling on html element, this is how we end up in !important hell later
const DAYS_MAP = [
          day: DAYS_MAP[i],
I see what you did here :sweat_smile: I’m really annoyed we are creating hardcoded locales with AM/PM, this is not how we show localised time.
can you suggest something else for me?
Maybe you create a fake moment with hours and minutes and just format it to show hours and minutes?
moment().set("hour", 12).set("minute", 28).format("LT")
// 12:28 PM (if moment.locale() === "en")
@jjaffeux FEATURE: Create notification schedule to automatically set do not disturb time by markvanlan · Pull Request #11665 · discourse/discourse · GitHub
This is looking much better!
Was thinking:
wday == 0 ? 6 : wday - 1
Unless of course wday is sometimes > 6 or < 1, which would be quite bad. Your code would otherwise get nil then.
Could we use metaprogramming to DRY this up?
Looks good now. Thanks for iterating on it!
