FEATURE: Decrypt images inline
diff --git a/assets/javascripts/discourse/initializers/hook-decrypt-post.js.es6 b/assets/javascripts/discourse/initializers/hook-decrypt-post.js.es6
index ba07058..59aac7c 100644
--- a/assets/javascripts/discourse/initializers/hook-decrypt-post.js.es6
+++ b/assets/javascripts/discourse/initializers/hook-decrypt-post.js.es6
@@ -1,6 +1,18 @@
 import { iconHTML, iconNode } from "discourse-common/lib/icon-library";
 import { renderSpinner } from "discourse/helpers/loading-spinner";
 import { ajax } from "discourse/lib/ajax";
+import {
+  fetchUnseenCategoryHashtags,
+  linkSeenCategoryHashtags
+} from "discourse/lib/link-category-hashtags";
+import {
+  fetchUnseenMentions,
+  linkSeenMentions
+} from "discourse/lib/link-mentions";
+import {
+  fetchUnseenTagHashtags,
+  linkSeenTagHashtags
+} from "discourse/lib/link-tag-hashtag";
 import { withPluginApi } from "discourse/lib/plugin-api";
 import showModal from "discourse/lib/show-modal";
 import { cookAsync } from "discourse/lib/text";
@@ -17,19 +29,13 @@ import {
   decrypt,
   verify
 } from "discourse/plugins/discourse-encrypt/lib/protocol";
-import { resolveAllShortUrls } from "pretty-text/upload-short-url";
+import { ATTACHMENT_CSS_CLASS } from "pretty-text/engines/discourse-markdown-it";
 import {
-  linkSeenMentions,
-  fetchUnseenMentions
-} from "discourse/lib/link-mentions";
-import {
-  linkSeenCategoryHashtags,
-  fetchUnseenCategoryHashtags
-} from "discourse/lib/link-category-hashtags";
-import {
-  linkSeenTagHashtags,
-  fetchUnseenTagHashtags
-} from "discourse/lib/link-tag-hashtag";
+  lookupCachedUploadUrl,
+  lookupUncachedUploadUrls,
+  MISSING
+} from "pretty-text/upload-short-url";
+import { Promise } from "rsvp";
 function checkMetadata(attrs, expected) {
   const actual = {
@@ -94,6 +100,105 @@ function checkMetadata(attrs, expected) {
   return diff;
+function downloadEncryptedFile(url, keyPromise) {
+  const downloadPromise = new Promise((resolve, reject) => {
+    var req = new XMLHttpRequest();
+    req.open("GET", url, true);
+    req.responseType = "arraybuffer";
+    req.onload = function() {
+      let filename = req.getResponseHeader("Content-Disposition");
+      if (filename) {
+        // Requires Access-Control-Expose-Headers: Content-Disposition.
+        filename = filename.match(/filename="(.*?)"/)[1];
+      resolve({ buffer: req.response, filename });
+    req.onerror = reject;
+    req.send(null);
+  return Promise.all([keyPromise, downloadPromise]).then(([key, download]) => {
+    const iv = download.buffer.slice(0, 12);
+    const content = download.buffer.slice(12);
+    return new Promise((resolve, reject) => {
+      window.crypto.subtle
+        .decrypt({ name: "AES-GCM", iv, tagLength: 128 }, key, content)
+        .then(resolve, reject);
+    }).then(buffer => ({
+      blob: new Blob([buffer], { type: "octet/stream" }),
+      name: download.filename
+function resolveShortUrlElement($el) {
+  if ($el.prop("tagName") === "A") {
+    const data = lookupCachedUploadUrl($el.data("orig-href"));
+    const url = data.short_path;
+    if (!url) {
+      return Promise.resolve();
+    $el.removeAttr("data-orig-href");
+    if (url !== MISSING) {
+      $el.attr("href", url);
+      const content = $el.text().split("|");
+      const topicId = $el.closest("[data-topic-id]").data("topic-id");
+      const keyPromise = getTopicKey(topicId);
+      if (content[1] === ATTACHMENT_CSS_CLASS) {
+        $el.addClass(ATTACHMENT_CSS_CLASS);
+        $el.text(content[0].replace(/\.encrypted$/, ""));
+        if (content[0].match(/\.encrypted$/)) {
+          $el.on("click", () => {
+            downloadEncryptedFile(url, keyPromise).then(file => {
+              const a = document.createElement("a");
+              a.href = window.URL.createObjectURL(file.blob);
+              a.download = file.name || content[0];
+              a.download = a.download.replace(/\.encrypted$/, "");
+              a.style.display = "none";
+              document.body.appendChild(a);
+              a.click();
+              document.body.removeChild(a);
+              window.URL.revokeObjectURL(a.href);
+            return false;
+  } else if ($el.prop("tagName") === "IMG") {
+    const data = lookupCachedUploadUrl($el.data("orig-src"));
+    const url = data.url;
+    if (!url) {
+    $el.removeAttr("data-orig-src");
+      if ($el.attr("alt").match(/\.encrypted$/)) {
+        return downloadEncryptedFile(url, keyPromise).then(file => {
+          $el.attr("alt", $el.attr("alt").replace(/\.encrypted$/, ""));
+          $el.attr("src", window.URL.createObjectURL(file.blob));
+      } else {
+        $el.attr("src", url);
 function postProcessPost(siteSettings, topicId, $post) {
   // Paint mentions.
   const unseenMentions = linkSeenMentions($post, siteSettings);
@@ -121,8 +226,25 @@ function postProcessPost(siteSettings, topicId, $post) {
-  // Paint short URLs.
-  resolveAllShortUrls(ajax);
+  // Resolve short URLs (first using cache and then using fresh data)
+  const urls = [];
+  const resolvePromises = [];
+  $post.find("img[data-orig-src], a[data-orig-href]").each((_, el) => {
+    const $el = $(el);
+    const url = $el.data("orig-src") || $el.data("orig-href");
+    if (lookupCachedUploadUrl(url).url) {
+      resolvePromises.push(resolveShortUrlElement($el));
+    } else {
+      urls.push(url);
+  lookupUncachedUploadUrls(urls, ajax).then(() => {
+      resolvePromises.push(resolveShortUrlElement($(el)));
+    return Promise.all(resolvePromises);
 export default {
diff --git a/assets/javascripts/discourse/initializers/hook-encrypt-upload.js.es6 b/assets/javascripts/discourse/initializers/hook-encrypt-upload.js.es6
new file mode 100644
index 0000000..e87de29
--- /dev/null
+++ b/assets/javascripts/discourse/initializers/hook-encrypt-upload.js.es6
@@ -0,0 +1,60 @@
+import { withPluginApi } from "discourse/lib/plugin-api";
+import {
+  ENCRYPT_ACTIVE,
+  getEncryptionStatus,
+  getTopicKey,
+  hasTopicKey
+} from "discourse/plugins/discourse-encrypt/lib/discourse";
+export default {
+  name: "hook-encrypt-upload",
+  initialize(container) {
+    const currentUser = container.lookup("current-user:main");
+    if (getEncryptionStatus(currentUser) !== ENCRYPT_ACTIVE) {
+      return;
+    withPluginApi("0.8.31", api => {
+      api.addComposerUploadHandler([".*"], (file, editor) => {
+        const controller = container.lookup("controller:composer");
+        const topicId = controller.get("model.topic.id");
+        if (!hasTopicKey(topicId)) {
+          if (controller.get("model.isEncrypted")) {
+            // Cannot encrypt uploads for new topics.
+            bootbox.alert(I18n.t("encrypt.encrypted_uploads"));
+            return false;
+          return true;
+        let reader = new FileReader();
+        reader.onloadend = () => {
+          const iv = window.crypto.getRandomValues(new Uint8Array(12));
+          getTopicKey(topicId)
+            .then(key =>
+              window.crypto.subtle.encrypt(
+                { name: "AES-GCM", iv, tagLength: 128 },
+                key,
+                reader.result
+            .then(buffer => {
+              let blob = new Blob([iv, buffer], {
+                type: "application/x-binary"
+              let f = new File([blob], `${file.name}.encrypted`);
+              editor.$().fileupload("send", {
+                files: [f],
GitHub sha: df871f61
Omg, awesomeness :heart::heart::heart:
