FEATURE: Digital Ocean Spaces compatibility for Object Storage (PR #9481)
DO does not implement tagging support for S3 objects. Removing our default empty tag fixes compatibility.
The expire_missing_assets rake task can’t be used with that service still, but this patch allows normal operation.
GitHub
was the empty tag added for a reason? are there any concerns around this change @andrewschleifer ?
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/using-scaleway-s3-compatible-object-storage/140603/25
I do not anticipate any problems, as an empty value shouldn’t actually apply a tag to the object anyway.
