FEATURE: empty array encoding compatibility with Sequel and ActiveRecord (#14)
  • empty array encoding
  • add performance, most commonly used data types to top in case
diff --git a/lib/mini_sql/inline_param_encoder.rb b/lib/mini_sql/inline_param_encoder.rb
index 78aa862..73897e2 100644
--- a/lib/mini_sql/inline_param_encoder.rb
+++ b/lib/mini_sql/inline_param_encoder.rb
@@ -50,19 +50,19 @@ module MiniSql
     def quote_val(value)
       case value
+      when String     then "'#{conn.escape_string(value.to_s)}'"
+      when Numeric    then value.to_s
+      when BigDecimal then value.to_s("F")
+      when Date, Time then "'#{quoted_date(value)}'"
+      when Symbol     then "'#{conn.escape_string(value.to_s)}'"
+      when true       then "true"
+      when false      then "false"
+      when nil        then "NULL"
+      when []         then "NULL"
       when Array
         value.map do |v|
           quote_val(v)
         end.join(', ')
-      when String
-        "'#{conn.escape_string(value.to_s)}'"
-      when true       then "true"
-      when false      then "false"
-      when nil        then "NULL"
-      when BigDecimal then value.to_s("F")
-      when Numeric then value.to_s
-      when Date, Time then "'#{quoted_date(value)}'"
-      when Symbol     then "'#{conn.escape_string(value.to_s)}'"
       else raise TypeError, "can't quote #{value.class.name}"
diff --git a/test/mini_sql/inline_param_encoder_test.rb b/test/mini_sql/inline_param_encoder_test.rb
index 5168163..348d930 100644
--- a/test/mini_sql/inline_param_encoder_test.rb
+++ b/test/mini_sql/inline_param_encoder_test.rb
@@ -30,6 +30,11 @@ module MiniSql
       assert_equal("select 'a', 'a'''", result)
+    def test_empty_array_encoding
+      result = @encoder.encode("select :str", str: [])
+      assert_equal("select NULL", result)
+    end
     def test_encode_times
       t = Time.parse('2010-10-01T02:22:00Z')
       result = @encoder.encode("select :t", t: t)
GitHub sha: e5d394fb
This commit appears in #14 which was merged by SamSaffron.
