FEATURE: Enable solved for topics with specific tags. (#164)
This PR adds a site setting called enable_solved_tags. Solved will be enabled for topics containing these tags, just like we do for specific categories.
diff --git a/app/serializers/concerns/topic_answer_mixin.rb b/app/serializers/concerns/topic_answer_mixin.rb
index 942704f..8c8fcc4 100644
--- a/app/serializers/concerns/topic_answer_mixin.rb
+++ b/app/serializers/concerns/topic_answer_mixin.rb
@@ -16,7 +16,7 @@ module TopicAnswerMixin
   def can_have_answer
     return true if SiteSetting.allow_solved_on_all_topics
     return false if object.closed || object.archived
-    scope.allow_accepted_answers_on_category?(object.category_id)
+    scope.allow_accepted_answer?(object.category_id, object.tags.map(&:name))
   def include_can_have_answer?
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 2eb4fe6..a00d2c0 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -13,6 +13,8 @@ en:
     disable_solved_education_message: "Disable education message for solved topics."
     accept_solutions_topic_author: "Allow the topic author to accept a solution."
     solved_add_schema_markup: "Add QAPage schema markup to HTML."
+    enable_solved_tags: "Allow users to select solutions on all topics (when unchecked, solutions can be enabled per category or tag)"
   reports:
     accepted_solutions:
       title: "Accepted solutions"
diff --git a/config/settings.yml b/config/settings.yml
index 335cdf5..f939b35 100644
--- a/config/settings.yml
+++ b/config/settings.yml
@@ -34,4 +34,7 @@ plugins:
       - "never"
       - "always"
       - "answered only"
+    type: tag_list
+    default: ""
index dd9fa14..ab2269d 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -282,7 +282,13 @@ SQL
     # a bit more prominent + cut down on pointless work
     return "" if SiteSetting.solved_add_schema_markup == "never"
-    return "" if !controller.guardian.allow_accepted_answers_on_category?(topic.category_id)
+    allowed = controller
+      .guardian
+      .allow_accepted_answers?(
+        topic.category_id, topic.tags.pluck(:name)
+    return "" if !allowed
     first_post = topic_view.posts&.first
     return "" if first_post&.post_number != 1
@@ -466,9 +472,17 @@ SQL
-    def allow_accepted_answers_on_category?(category_id)
+    def allow_accepted_answers?(category_id, tag_names = [])
+      if SiteSetting.enable_solved_tags.present? && tag_names.present?
+        allowed_tags = SiteSetting.enable_solved_tags.split('|')
+        is_allowed = (tag_names & allowed_tags).present?
+        return true if is_allowed
+      end
+      return false if category_id.blank?
       self.class.reset_accepted_answer_cache unless @@allowed_accepted_cache["allowed"]
       @@allowed_accepted_cache["allowed"].include?(category_id)
@@ -476,7 +490,7 @@ SQL
     def can_accept_answer?(topic, post)
       return false if !authenticated?
       return false if !topic || !post || post.whisper?
-      return false if !allow_accepted_answers_on_category?(topic.category_id)
+      return false if !allow_accepted_answers?(topic.category_id, topic.tags.map(&:name))
       return true if is_staff?
       return true if current_user.trust_level >= SiteSetting.accept_all_solutions_trust_level
@@ -606,13 +620,13 @@ SQL
   on(:before_post_publish_changes) do |post_changes, topic_changes, options|
-    category_id_changes = topic_changes.diff["category_id"]
-    next if category_id_changes.blank?
+    category_id_changes = topic_changes.diff['category_id'].to_a
+    tag_changes = topic_changes.diff['tags'].to_a
-    old_category_allows = Guardian.new.allow_accepted_answers_on_category?(category_id_changes[0])
-    new_category_allows = Guardian.new.allow_accepted_answers_on_category?(category_id_changes[1])
+    old_allowed = Guardian.new.allow_accepted_answers?(category_id_changes[0], tag_changes[0])
+    new_allowed = Guardian.new.allow_accepted_answers?(category_id_changes[1], tag_changes[1])
-    options[:refresh_stream] = true if old_category_allows != new_category_allows
+    options[:refresh_stream] = true if old_allowed != new_allowed
   on(:after_populate_dev_records) do |records, type|
diff --git a/spec/components/post_revisor_spec.rb b/spec/components/post_revisor_spec.rb
index 33ce5b3..d60a07c 100644
--- a/spec/components/post_revisor_spec.rb
+++ b/spec/components/post_revisor_spec.rb
@@ -5,6 +5,7 @@ require 'post_revisor'
 describe PostRevisor do
   fab!(:category) { Fabricate(:category_with_definition) }
+  fab!(:admin) { Fabricate(:admin) }
   fab!(:category_solved) do
     category = Fabricate(:category_with_definition)
@@ -17,15 +18,48 @@ describe PostRevisor do
     post = Fabricate(:post, topic: topic)
     messages = MessageBus.track_publish("/topic/#{topic.id}") do
-      described_class.new(post).revise!(Fabricate(:admin), { category_id: category.id })
+      described_class.new(post).revise!(admin, { category_id: category.id })
     expect(messages.first.data[:refresh_stream]).to eq(nil)
-      described_class.new(post).revise!(Fabricate(:admin), { category_id: category_solved.id })
+      described_class.new(post).revise!(admin, { category_id: category_solved.id })
     expect(messages.first.data[:refresh_stream]).to eq(true)
+  context 'Allowing solved via tags' do
+    before do
+      SiteSetting.solved_enabled = true
+      SiteSetting.tagging_enabled = true
+    end
+    fab!(:tag1) { Fabricate(:tag) }
+    fab!(:tag2) { Fabricate(:tag) }
+    fab!(:topic) { Fabricate(:topic) }
+    let(:post) { Fabricate(:post, topic: topic) }
+    it 'sets the refresh option after adding an allowed tag' do
+      SiteSetting.enable_solved_tags = tag1.name
+      messages = MessageBus.track_publish("/topic/#{topic.id}") do
+        described_class.new(post).revise!(admin, tags: [tag1.name])
+      end
+      expect(messages.first.data[:refresh_stream]).to eq(true)
+    end
+    it 'sets the refresh option if the added tag matches any of the allowed tags' do
+      SiteSetting.enable_solved_tags = [tag1, tag2].map(&:name).join('|')
+        described_class.new(post).revise!(admin, tags: [tag2.name])
+      end
+    end
+  end
diff --git a/spec/requests/topics_controller_spec.rb b/spec/requests/topics_controller_spec.rb
index 67e85eb..b101014 100644
--- a/spec/requests/topics_controller_spec.rb
+++ b/spec/requests/topics_controller_spec.rb
@@ -31,33 +31,67 @@ RSpec.describe TopicsController do
-  before do
-    SiteSetting.allow_solved_on_all_topics = true
-  end
+  context 'solved enabled on every topic' do
+    before do
+      SiteSetting.allow_solved_on_all_topics = true
+    end
+    it 'should include correct schema information in header' do
+      get "/t/#{topic.slug}/#{topic.id}"
+      expect(response.body).to include(schema_json(0))
-  it 'should include correct schema information in header' do
-    get "/t/#{topic.slug}/#{topic.id}"
+      p2.custom_fields["is_accepted_answer"] = true
+      p2.save_custom_fields
+      topic.custom_fields["accepted_answer_post_id"] = p2.id
+      topic.save_custom_fields
-    expect(response.body).to include(schema_json(0))
-    p2.custom_fields["is_accepted_answer"] = true
-    p2.save_custom_fields
-    topic.custom_fields["accepted_answer_post_id"] = p2.id
-    topic.save_custom_fields
+      expect(response.body).to include(schema_json(1))
+    end
+    it 'should include quoted content in schema information' do
+      post = topic.first_post
+      post.raw = "[quote]This is a quoted text.[/quote]"
+      post.save!
+      post.rebake!
GitHub sha: 66999ee3fbf89731491d7fbc12933b5b742519e9
