FEATURE: experimental hidden setting for draft backups
Under exceptional situations the automatic draft feature can fail.
This new hidden, default off site setting backup_drafts_to_pm_length will automatically backup any draft that is saved by the system to a dedicated PM (originating from self)
The body of that PM will contain the text of the reply.
We can enable this feature strategically on sites exhibiting issues to diagnose issues with the draft system and offer a recourse to users who appear to lose drafts. We automatically checkpoint these drafts every 5 minutes forcing a new revision each 5 minutes so you can revert to old content.
Longer term we are considering automatically enabling this kind of feature for extremely long drafts where the risk is really high one could lose days of writing.
diff --git a/app/models/backup_draft_post.rb b/app/models/backup_draft_post.rb
new file mode 100644
index 0000000000..9dd552452b
--- /dev/null
+++ b/app/models/backup_draft_post.rb
@@ -0,0 +1,23 @@
+class BackupDraftPost < ActiveRecord::Base
+  belongs_to :user
+  belongs_to :post
+end
+# == Schema Information
+# Table name: backup_draft_posts
+#  id         :bigint           not null, primary key
+#  user_id    :integer          not null
+#  post_id    :integer          not null
+#  key        :string           not null
+#  created_at :datetime         not null
+#  updated_at :datetime         not null
+# Indexes
+#  index_backup_draft_posts_on_post_id          (post_id) UNIQUE
+#  index_backup_draft_posts_on_user_id_and_key  (user_id,key) UNIQUE
diff --git a/app/models/backup_draft_topic.rb b/app/models/backup_draft_topic.rb
index 0000000000..c3fdfe1204
--- /dev/null
+++ b/app/models/backup_draft_topic.rb
@@ -0,0 +1,22 @@
+class BackupDraftTopic < ActiveRecord::Base
+  belongs_to :user
+  belongs_to :topic
+end
+# Table name: backup_draft_topics
+#  topic_id   :integer          not null
+# Indexes
+#  index_backup_draft_topics_on_topic_id  (topic_id) UNIQUE
+#  index_backup_draft_topics_on_user_id   (user_id) UNIQUE
diff --git a/app/models/draft.rb b/app/models/draft.rb
index 9905cbe1c5..287d25c263 100644
--- a/app/models/draft.rb
+++ b/app/models/draft.rb
@@ -6,6 +6,10 @@ class Draft < ActiveRecord::Base
   EXISTING_TOPIC ||= 'topic_'
   def self.set(user, key, sequence, data)
+    if SiteSetting.backup_drafts_to_pm_length > 0 && SiteSetting.backup_drafts_to_pm_length < data.length
+      backup_draft(user, key, sequence, data)
+    end
     if d = find_draft(user, key)
       return if d.sequence > sequence
@@ -96,6 +100,92 @@ class Draft < ActiveRecord::Base
     Draft.where("updated_at < ?", delete_drafts_older_than_n_days).destroy_all
+  def self.backup_draft(user, key, sequence, data)
+    reply = JSON.parse(data)["reply"] || ""
+    return if reply.length < SiteSetting.backup_drafts_to_pm_length
+    post_id = BackupDraftPost.where(user_id: user.id, key: key).pluck(:post_id).first
+    post = Post.where(id: post_id).first if post_id
+    if post_id && !post
+      BackupDraftPost.where(user_id: user.id, key: key).delete_all
+    end
+    indented_reply = reply.split("\n").map! do |l|
+      "    #{l}"
+    end
+    draft_body = <<~MD
+      #{indented_reply.join("\n")}
+      `‍``text
+      seq: #{sequence}
+      key: #{key}
+    MD
+    return if post && post.raw == draft_body
+    if !post
+      topic = ensure_draft_topic!(user)
+      Post.transaction do
+        post = PostCreator.new(
+          user,
+          raw: draft_body,
+          skip_jobs: true,
+          skip_validations: true,
+          topic_id: topic.id,
+        ).create
+        BackupDraftPost.create!(user_id: user.id, key: key, post_id: post.id)
+      end
+    elsif post.updated_at > 5.minutes.ago
+      # bypass all validations here to maximize speed
+      post.update_columns(
+        raw: draft_body,
+        cooked: PrettyText.cook(draft_body),
+        updated_at: Time.zone.now
+    else
+      revisor = PostRevisor.new(post, post.topic)
+      revisor.revise!(user, { raw: draft_body },
+        bypass_bump: true,
+        skip_staff_log: true,
+        bypass_rate_limiter: true
+    end
+  rescue => e
+    Discourse.warn_exception(e, message: "Failed to backup draft")
+  end
+  def self.ensure_draft_topic!(user)
+    topic_id = BackupDraftTopic.where(user_id: user.id).pluck(:topic_id).first
+    topic = Topic.find_by(id: topic_id) if topic_id
+    if topic_id && !topic
+      BackupDraftTopic.where(user_id: user.id).delete_all
+    end
+    if !topic
+      Topic.transaction do
+        creator = PostCreator.new(
+          user,
+          title: I18n.t("draft_backup.pm_title"),
+          archetype: Archetype.private_message,
+          raw: I18n.t("draft_backup.pm_body"),
+          skip_jobs: true,
+          target_usernames: user.username
+        topic = creator.create.topic
+        BackupDraftTopic.create!(topic_id: topic.id, user_id: user.id)
+      end
+    end
+    topic
+  end
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 1e72fbf09b..d88a01ccc1 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -871,6 +871,9 @@ en:
       short_description: "Like this post"
       long_form: "liked this"
+  draft_backup:
+    pm_title: "Backup Drafts from ongoing topics"
+    pm_body: "Topic containing backup drafts"
   user_activity:
     no_default:
       self: "You have no activity yet."
@@ -1993,7 +1996,7 @@ en:
     notify_about_flags_after: "If there are flags that haven't been handled after this many hours, send a personal message to moderators. Set to 0 to disable."
     show_create_topics_notice: "If the site has fewer than 5 public topics, show a notice asking admins to create some topics."
-    delete_drafts_older_than_n_days: Delete drafts older than (n) days.
+    delete_drafts_older_than_n_days: "Delete drafts older than (n) days."
     bootstrap_mode_min_users: "Minimum number of users required to disable bootstrap mode (set to 0 to disable)"
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 603ac3cc89..c452320eac 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1858,6 +1858,10 @@ uncategorized:
     default: 180
+  backup_drafts_to_pm_length:
+    default: 0
+    hidden: true
   tos_topic_id:
     default: -1
     hidden: true
diff --git a/db/migrate/20191017044811_add_draft_backup_tables.rb b/db/migrate/20191017044811_add_draft_backup_tables.rb
index 0000000000..6177426c50
--- /dev/null
+++ b/db/migrate/20191017044811_add_draft_backup_tables.rb
@@ -0,0 +1,25 @@
+class AddDraftBackupTables < ActiveRecord::Migration[6.0]
+  def change
+    create_table :backup_draft_topics do |t|
+      t.integer :user_id, null: false
+      t.integer :topic_id, null: false
+      t.timestamps
+    end
+    create_table :backup_draft_posts do |t|
+      t.integer :post_id, null: false
+      t.string :key, null: false
+      t.timestamps
+    end
+    add_index :backup_draft_posts, [:user_id, :key], unique: true
+    add_index :backup_draft_posts, [:post_id], unique: true
+    add_index :backup_draft_topics, [:user_id], unique: true
+    add_index :backup_draft_topics, [:topic_id], unique: true
+  end
+end
diff --git a/lib/post_creator.rb b/lib/post_creator.rb
index bf1fe848d7..561720dfb0 100644
--- a/lib/post_creator.rb
+++ b/lib/post_creator.rb
@@ -34,6 +34,7 @@ class PostCreator
   #                             dequeue before the commit finishes. If you do this, be sure to
   #                             call `enqueue_jobs` after the transaction is comitted.
   #   hidden_reason_id        - Reason for hiding the post (optional)
+  #   skip_validations        - Do not validate any of the content in the post
   #   When replying to a topic:
   #     topic_id              - topic we're replying to
diff --git a/spec/models/draft_spec.rb b/spec/models/draft_spec.rb
index 2cdf5fa5d4..b65c20c3b7 100644
--- a/spec/models/draft_spec.rb
+++ b/spec/models/draft_spec.rb
@@ -3,37 +3,70 @@
 require 'rails_helper'
 describe Draft do
-  before do
-    @user = Fabricate(:user)
+  fab!(:user) do
+    Fabricate(:user)
GitHub sha: f5d1aff8
