FEATURE: External auth when redeeming invites
This feature (when enabled) will allow for invite_only sites to require external authentication before they can redeem an invite.
  • Created hidden site setting to toggle this
  • Enables sending invites with local logins disabled
  • OAuth button added to invite form
  • Requires OAuth email address to match invite email address
  • Prevents redeeming invite if OAuth authentication fails
diff --git a/app/assets/javascripts/discourse/controllers/invites-show.js.es6 b/app/assets/javascripts/discourse/controllers/invites-show.js.es6
index 2664a95..701a757 100644
--- a/app/assets/javascripts/discourse/controllers/invites-show.js.es6
+++ b/app/assets/javascripts/discourse/controllers/invites-show.js.es6
@@ -5,6 +5,7 @@ import { ajax } from "discourse/lib/ajax";
 import PasswordValidation from "discourse/mixins/password-validation";
 import UsernameValidation from "discourse/mixins/username-validation";
 import NameValidation from "discourse/mixins/name-validation";
+import InviteEmailAuthValidation from "discourse/mixins/invite-email-auth-validation";
 import UserFieldsValidation from "discourse/mixins/user-fields-validation";
 import { findAll as findLoginMethods } from "discourse/models/login-method";
@@ -12,8 +13,11 @@ export default Ember.Controller.extend(
   PasswordValidation,
   UsernameValidation,
   NameValidation,
+  InviteEmailAuthValidation,
   UserFieldsValidation,
+    login: Ember.inject.controller(),
     invitedBy: Ember.computed.alias("model.invited_by"),
     email: Ember.computed.alias("model.email"),
     accountUsername: Ember.computed.alias("model.username"),
@@ -22,6 +26,7 @@ export default Ember.Controller.extend(
     errorMessage: null,
     userFields: null,
     inviteImageUrl: getUrl("/images/envelope.svg"),
+    hasAuthOptions: Ember.computed.notEmpty("authOptions"),
     @computed
     welcomeTitle() {
@@ -35,24 +40,40 @@ export default Ember.Controller.extend(
       return I18n.t("invites.your_email", { email: email });
+    authProviderDisplayName(providerName) {
+      const matchingProvider = findLoginMethods().find(provider => {
+        return provider.name === providerName;
+      return matchingProvider
+        ? matchingProvider.get("prettyName")
+        : providerName;
     @computed
     externalAuthsEnabled() {
       return findLoginMethods().length > 0;
+    @computed
+    inviteOnlyOauthEnabled() {
+      return this.siteSettings.enable_invite_only_oauth;
     @computed(
       "usernameValidation.failed",
       "passwordValidation.failed",
       "nameValidation.failed",
-      "userFieldsValidation.failed"
+      "userFieldsValidation.failed",
+      "inviteEmailAuthValidation.failed",
     submitDisabled(
       usernameFailed,
       passwordFailed,
       nameFailed,
-      userFieldsFailed
+      userFieldsFailed,
+      inviteEmailAuthFailed,
-      return usernameFailed || passwordFailed || nameFailed || userFieldsFailed;
+      return usernameFailed || passwordFailed || nameFailed || userFieldsFailed || inviteEmailAuthFailed;
     @computed
@@ -63,6 +84,10 @@ export default Ember.Controller.extend(
     actions: {
+      externalLogin(provider) {
+        this.login.send("externalLogin", provider);
       submit() {
         const userFields = this.userFields;
         let userCustomFields = {};
diff --git a/app/assets/javascripts/discourse/controllers/login.js.es6 b/app/assets/javascripts/discourse/controllers/login.js.es6
index 19da455..76f33c9 100644
--- a/app/assets/javascripts/discourse/controllers/login.js.es6
+++ b/app/assets/javascripts/discourse/controllers/login.js.es6
@@ -20,6 +20,7 @@ const AuthErrors = [
 export default Ember.Controller.extend(ModalFunctionality, {
   createAccount: Ember.inject.controller(),
+  invitesShow: Ember.inject.controller(),
   forgotPassword: Ember.inject.controller(),
   application: Ember.inject.controller(),
@@ -353,14 +354,23 @@ export default Ember.Controller.extend(ModalFunctionality, {
       return;
-    const createAccountController = this.createAccount;
-    createAccountController.setProperties({
-      accountEmail: options.email,
-      accountUsername: options.username,
-      accountName: options.name,
-      authOptions: Ember.Object.create(options)
-    showModal("createAccount");
+    if (this.siteSettings.enable_invite_only_oauth) {
+      const invitesShowController = this.invitesShow;
+      invitesShowController.setProperties({
+        accountEmail: options.email,
+        accountUsername: options.username,
+        accountName: options.name,
+        authOptions: Ember.Object.create(options)
+    } else {
+      const createAccountController = this.createAccount;
+      createAccountController.setProperties({
+      showModal("createAccount");
diff --git a/app/assets/javascripts/discourse/mixins/invite-email-auth-validation.js.es6 b/app/assets/javascripts/discourse/mixins/invite-email-auth-validation.js.es6
new file mode 100644
index 0000000..733573d
--- /dev/null
+++ b/app/assets/javascripts/discourse/mixins/invite-email-auth-validation.js.es6
@@ -0,0 +1,38 @@
+import InputValidation from "discourse/models/input-validation";
+import { default as computed } from "ember-addons/ember-computed-decorators";
+export default Ember.Mixin.create({
+  @computed()
+  nameInstructions() {
+  // Validate the name.
+  @computed("accountEmail", "authOptions.email", "authOptions.email_valid", "authOptions.auth_provider")
+  inviteEmailAuthValidation() {
+    if (
+      !this.siteSettings.enable_invite_only_oauth ||
+      (this.siteSettings.enable_invite_only_oauth &&
+      this.get("authOptions.email") === this.email &&
+      this.get("authOptions.email_valid"))
+      return InputValidation.create({
+        ok: true,
+        reason: I18n.t("user.email.authenticated", {
+          provider: this.authProviderDisplayName(
+            this.get("authOptions.auth_provider")
+      failed: true,
+      reason: I18n.t("user.email.invite_email_auth_invalid", {
diff --git a/app/assets/javascripts/discourse/templates/invites/show.hbs b/app/assets/javascripts/discourse/templates/invites/show.hbs
index 6b3b461..467d918 100644
--- a/app/assets/javascripts/discourse/templates/invites/show.hbs
+++ b/app/assets/javascripts/discourse/templates/invites/show.hbs
@@ -14,55 +14,98 @@
       {{else}}
         <p>{{i18n 'invites.invited_by'}}</p>
         <p>{{user-info user=invitedBy}}</p>
-        <p>{{{yourEmailMessage}}}
+        <p>
+        {{{yourEmailMessage}}}
+        {{#if inviteOnlyOauthEnabled }}
+          {{login-buttons externalLogin=(action "externalLogin")}}
+        {{/if}}
         {{#if externalAuthsEnabled}}
-             {{i18n 'invites.social_login_available'}}
+          {{#unless inviteOnlyOauthEnabled}}
+            {{i18n 'invites.social_login_available'}}
+          {{/unless}}
         {{/if}}
         </p>
-        <form>
-          <div class="input username-input">
-            <label>{{i18n 'user.username.title'}}</label>
-            {{input value=accountUsername id="new-account-username" name="username" maxlength=maxUsernameLength autocomplete="discourse"}}
-            &nbsp;{{input-tip validation=usernameValidation id="username-validation"}}
-            <div class="instructions">{{i18n 'user.username.instructions'}}</div>
-          </div>
-          {{#if fullnameRequired}}
-            <div class="input name-input">
-              <label>{{i18n 'invites.name_label'}}</label>
-              {{input value=accountName id="new-account-name" name="name"}}
-              <div class="instructions">{{nameInstructions}}</div>
-            </div>
+        {{#if hasAuthOptions}}
+            {{input-tip validation=inviteEmailAuthValidation id="account-email-validation"}}
           {{/if}}
+          <form>
GitHub sha: 87a0a666
Small tip, you can shorten this to
const matchingProvider = findLoginMethods().find(p => p.name === providerName)
This whole computed property can be replaced with the Ember.computed.or “alias”
submitDisabled: Ember.computed.or("usernameValidation.failed", "passwordValidation.failed", ...)
Any reasons why you’re declaring this variable? Seems like it’s only being used the line below?
Ditto ^^
I find this quite hard to read. Any way we could extract part of this condition into a temporary (but adequately named) variable?
Same as on the client-side. Can we either extract part of the condition into temporary variables or use “return early” to ease the understanding of that method?
This is odd because the empty string is not returned.
Ohh yea, I forgot I did that and then moved on to bigger problems. I’ll clean that up.
REVERT: External auth when redeeming invites
