FEATURE: Filter settings by plugin (#9692)
diff --git a/app/assets/javascripts/admin/controllers/admin-site-settings.js b/app/assets/javascripts/admin/controllers/admin-site-settings.js
index ac84553..e3225b1 100644
--- a/app/assets/javascripts/admin/controllers/admin-site-settings.js
+++ b/app/assets/javascripts/admin/controllers/admin-site-settings.js
@@ -15,12 +15,32 @@ export default Controller.extend({
     // If we have no content, don't bother filtering anything
     if (!!isEmpty(this.allSiteSettings)) return;
-    let filter;
+    let filter, pluginFilter;
     if (this.filter) {
-      filter = this.filter.toLowerCase().trim();
+      filter = this.filter
+        .toLowerCase()
+        .split(" ")
+        .filter(word => {
+          if (word.length === 0) {
+            return false;
+          if (word.startsWith("plugin:")) {
+            pluginFilter = word.substr("plugin:".length).trim();
+            return false;
+          return true;
+        .join(" ")
+        .trim();
-    if ((!filter || 0 === filter.length) && !this.onlyOverridden) {
+    if (
+      (!filter || 0 === filter.length) &&
+      (!pluginFilter || 0 === pluginFilter.length) &&
+      !this.onlyOverridden
       this.set("visibleSiteSettings", this.allSiteSettings);
       if (this.categoryNameKey === "all_results") {
         this.transitionToRoute("adminSiteSettings");
@@ -39,6 +59,7 @@ export default Controller.extend({
     this.allSiteSettings.forEach(settingsCategory => {
       const siteSettings = settingsCategory.siteSettings.filter(item => {
         if (this.onlyOverridden && !item.get("overridden")) return false;
+        if (pluginFilter && item.plugin !== pluginFilter) return false;
         if (filter) {
           const setting = item.get("setting").toLowerCase();
           return (
diff --git a/app/assets/javascripts/admin/routes/admin-plugins.js b/app/assets/javascripts/admin/routes/admin-plugins.js
index c4af286..261610a 100644
--- a/app/assets/javascripts/admin/routes/admin-plugins.js
+++ b/app/assets/javascripts/admin/routes/admin-plugins.js
@@ -9,18 +9,12 @@ export default Route.extend({
       const controller = this.controllerFor("adminSiteSettings");
       this.transitionTo("adminSiteSettingsCategory", "plugins").then(() => {
         if (plugin) {
-          const siteSettingFilter = plugin.get("enabled_setting_filter");
-          const match = /^(.*)_enabled/.exec(plugin.get("enabled_setting"));
-          const filter = siteSettingFilter || match[1];
-          if (filter) {
-            // filterContent() is normally on a debounce from typing.
-            // Because we don't want the default of "All Results", we tell it
-            // to skip the next debounce.
-            controller.set("filter", filter);
-            controller.set("_skipBounce", true);
-            controller.filterContentNow("plugins");
+          // filterContent() is normally on a debounce from typing.
+          // Because we don't want the default of "All Results", we tell it
+          // to skip the next debounce.
+          controller.set("filter", `plugin:${plugin.id}`);
+          controller.set("_skipBounce", true);
+          controller.filterContentNow("plugins");
diff --git a/app/models/site_setting.rb b/app/models/site_setting.rb
index 7925f91..bc96633 100644
--- a/app/models/site_setting.rb
+++ b/app/models/site_setting.rb
@@ -12,9 +12,9 @@ class SiteSetting < ActiveRecord::Base
     true
-  def self.load_settings(file)
+  def self.load_settings(file, plugin: nil)
     SiteSettings::YamlLoader.new(file).load do |category, name, default, opts|
-      setting(name, default, opts.merge(category: category))
+      setting(name, default, opts.merge(category: category, plugin: plugin))
@@ -22,7 +22,7 @@ class SiteSetting < ActiveRecord::Base
   unless Rails.env.test? && ENV['LOAD_PLUGINS'] != "1"
     Dir[File.join(Rails.root, "plugins", "*", "config", "settings.yml")].each do |file|
-      load_settings(file)
+      load_settings(file, plugin: file.split("/")[-3])
diff --git a/app/serializers/admin_plugin_serializer.rb b/app/serializers/admin_plugin_serializer.rb
index 3b8fc0e..843ca58 100644
--- a/app/serializers/admin_plugin_serializer.rb
+++ b/app/serializers/admin_plugin_serializer.rb
@@ -8,11 +8,10 @@ class AdminPluginSerializer < ApplicationSerializer
              :admin_route,
              :enabled,
              :enabled_setting,
-             :is_official,
-             :enabled_setting_filter
+             :is_official
   def id
-    object.metadata.name
+    object.directory_name
   def name
@@ -39,14 +38,6 @@ class AdminPluginSerializer < ApplicationSerializer
     object.enabled_site_setting
-  def include_enabled_setting_filter?
-    object.enabled_site_setting_filter.present?
-  end
-  def enabled_setting_filter
-  end
   def include_url?
     url.present?
diff --git a/lib/discourse.rb b/lib/discourse.rb
index 9bdbc2b..649fb00 100644
--- a/lib/discourse.rb
+++ b/lib/discourse.rb
@@ -801,7 +801,7 @@ module Discourse
     redis_key = "deprecate-notice-#{digest}"
     if !Discourse.redis.without_namespace.get(redis_key)
-      Rails.logger.warn(warning)
+      Rails.logger.warn(warning) if Rails.logger
       begin
         Discourse.redis.without_namespace.setex(redis_key, 3600, "x")
       rescue Redis::CommandError => e
diff --git a/lib/plugin/instance.rb b/lib/plugin/instance.rb
index 13064a7..006aa31 100644
--- a/lib/plugin/instance.rb
+++ b/lib/plugin/instance.rb
@@ -626,11 +626,7 @@ class Plugin::Instance
   def enabled_site_setting_filter(filter = nil)
-    if filter
-      @enabled_setting_filter = filter
-    else
-    end
+    Discourse.deprecate("`enabled_site_setting_filter` is deprecated", output_in_test: true)
   def enabled_site_setting(setting = nil)
diff --git a/lib/site_setting_extension.rb b/lib/site_setting_extension.rb
index 64fe9d6..09b616e 100644
--- a/lib/site_setting_extension.rb
+++ b/lib/site_setting_extension.rb
@@ -110,6 +110,10 @@ module SiteSettingExtension
     @secret_settings ||= []
+  def plugins
+    @plugins ||= {}
+  end
   def setting(name_arg, default = nil, opts = {})
     name = name_arg.to_sym
@@ -158,6 +162,10 @@ module SiteSettingExtension
         secret_settings << name
+      if opts[:plugin]
+        plugins[name] = opts[:plugin]
+      end
       type_supervisor.load_setting(
         name,
         opts.extract!(*SiteSettings::TypeSupervisor::CONSUMED_OPTS)
@@ -246,6 +254,8 @@ module SiteSettingExtension
         placeholder: placeholder(s)
       }.merge!(type_hash)
+      opts[:plugin] = plugins[s] if plugins[s]
       opts
     end.unshift(locale_setting_hash)
diff --git a/spec/components/plugin/instance_spec.rb b/spec/components/plugin/instance_spec.rb
index 26dd0d3..1c5bee7 100644
--- a/spec/components/plugin/instance_spec.rb
+++ b/spec/components/plugin/instance_spec.rb
@@ -502,21 +502,6 @@ describe Plugin::Instance do
-  describe '#enabled_site_setting_filter' do
-    describe 'when filter is blank' do
-      it 'should return the right value' do
-        expect(Plugin::Instance.new.enabled_site_setting_filter).to eq(nil)
-      end
-    end
-    it 'should set the right value' do
-      instance = Plugin::Instance.new
-      instance.enabled_site_setting_filter('test')
-      expect(instance.enabled_site_setting_filter).to eq('test')
-    end
-  end
   describe '#register_reviewable_types' do
     it 'Overrides the existing Reviewable types adding new ones' do
       current_types = Reviewable.types
diff --git a/test/javascripts/acceptance/admin-site-settings-test.js b/test/javascripts/acceptance/admin-site-settings-test.js
index b0975a9..f02d093 100644
GitHub sha: 8149bfba
This commit appears in #9692 which was approved by eviltrout. It was merged by nbianca.
