FEATURE: implements initial support for post events (#24)
diff --git a/app/controllers/discourse_calendar/invitees_controller.rb b/app/controllers/discourse_calendar/invitees_controller.rb
new file mode 100644
index 0000000..d6f1d2b
--- /dev/null
+++ b/app/controllers/discourse_calendar/invitees_controller.rb
@@ -0,0 +1,45 @@
+module DiscourseCalendar
+  class InviteesController < ::ApplicationController
+    before_action :ensure_logged_in
+    def index
+      post_event_invitees = PostEvent.find(params['post-event-id']).invitees
+      if params[:filter]
+        post_event_invitees = post_event_invitees.joins(:user).where("users.username LIKE '%#{params[:filter]}%'")
+      end
+      render json: ActiveModel::ArraySerializer.new(post_event_invitees.limit(10), each_serializer: InviteeSerializer).as_json
+    end
+    def update
+      invitee = Invitee.find(params[:id])
+      guardian.ensure_can_act_on_invitee!(invitee)
+      status = Invitee.statuses[invitee_params[:status].to_sym]
+      invitee.update_attendance(status: status)
+      invitee.post_event.publish_update!
+      render json: InviteeSerializer.new(invitee)
+    end
+    def create
+      post_event = PostEvent.find(invitee_params[:post_id])
+      guardian.ensure_can_act_on_post_event!(post_event)
+      invitee = Invitee.create!(
+        status: status,
+        post_id: invitee_params[:post_id],
+        user_id: current_user.id,
+    end
+    private
+    def invitee_params
+      params.require(:invitee).permit(:status, :post_id)
+    end
+  end
+end
diff --git a/app/controllers/discourse_calendar/post_events_controller.rb b/app/controllers/discourse_calendar/post_events_controller.rb
index 0000000..52891cd
--- /dev/null
+++ b/app/controllers/discourse_calendar/post_events_controller.rb
@@ -0,0 +1,92 @@
+  class PostEventsController < ::ApplicationController
+    def index
+      post_events = PostEvent.visible.where("starts_at > ?", Time.now).limit(10)
+        post_events,
+        each_serializer: PostEventSerializer,
+        scope: guardian).as_json
+    end
+    def show
+      post_event = DiscourseCalendar::PostEvent.find(params[:id])
+      guardian.ensure_can_see!(post_event.post)
+      serializer = PostEventSerializer.new(post_event, scope: guardian)
+      render_json_dump(serializer)
+    end
+    def destroy
+      post_event.publish_update!
+      post_event.destroy
+      render json: success_json
+    end
+    def update
+      DistributedMutex.synchronize("discourse-calendar[post-event-invitee-update]") do
+        guardian.ensure_can_edit!(post_event.post)
+        post_event.enforce_utc!(post_event_params)
+        case post_event_params[:status].to_i
+        when PostEvent.statuses[:private]
+          raw_invitees = Array(post_event_params[:raw_invitees])
+          post_event.update!(post_event_params.merge(raw_invitees: raw_invitees))
+          post_event.enforce_raw_invitees!
+        when PostEvent.statuses[:public]
+          post_event.update!(post_event_params.merge(raw_invitees: []))
+        when PostEvent.statuses[:standalone]
+          post_event.invitees.destroy_all
+        end
+      end
+    end
+    def create
+      post_event = DiscourseCalendar::PostEvent.new(post_event_params)
+      guardian.ensure_can_create_post_event!(post_event)
+        post_event.update!(raw_invitees: raw_invitees)
+        post_event.fill_invitees!
+        post_event.notify_invitees!
+      when PostEvent.statuses[:public], PostEvent.statuses[:standalone]
+      end
+    end
+    private
+    def post_event_params
+      params
+        .require(:post_event)
+        .permit(
+          :id,
+          :name,
+          :starts_at,
+          :ends_at,
+          :status,
+          :display_invitees,
+          raw_invitees: []
+    end
+  end
+end
diff --git a/app/controllers/discourse_calendar/upcoming_events_controller.rb b/app/controllers/discourse_calendar/upcoming_events_controller.rb
index 0000000..f2f1502
--- /dev/null
+++ b/app/controllers/discourse_calendar/upcoming_events_controller.rb
@@ -0,0 +1,10 @@
+  class UpcomingEventsController < ::ApplicationController
+    def index
+    end
+  end
+end
diff --git a/app/models/discourse_calendar/invitee.rb b/app/models/discourse_calendar/invitee.rb
index 0000000..1f321ed
--- /dev/null
+++ b/app/models/discourse_calendar/invitee.rb
@@ -0,0 +1,22 @@
+  class Invitee < ActiveRecord::Base
+    self.table_name = 'discourse_calendar_invitees'
+    belongs_to :post_event, foreign_key: :post_id
+    belongs_to :user
+    scope :with_status, ->(status) {
+      where(status: Invitee.statuses[status])
+    def self.statuses
+      @statuses ||= Enum.new(going: 0, interested: 1, not_going: 2)
+    end
+    def update_attendance(params)
+      self.update!(params)
+    end
+  end
+end
diff --git a/app/models/discourse_calendar/post_event.rb b/app/models/discourse_calendar/post_event.rb
index 0000000..9817352
--- /dev/null
+++ b/app/models/discourse_calendar/post_event.rb
@@ -0,0 +1,142 @@
+  class PostEvent < ActiveRecord::Base
+    self.table_name = 'discourse_calendar_post_events'
+    def self.attributes_protected_by_default
+      super - ['id']
+    end
+    has_many :invitees, foreign_key: :post_id, dependent: :delete_all
+    belongs_to :post, foreign_key: :id
+    scope :visible, -> { where(deleted_at: nil) }
+    validates :name,
+      length: { in: 5..30 },
+      unless: -> (post_event) { post_event.name.blank? }
+    validate :raw_invitees_length
+    def raw_invitees_length
+      if self.raw_invitees && self.raw_invitees.length > 10
+        errors.add(:base, I18n.t("discourse_calendar.post_event.errors.raw_invitees_length", count: 10))
+      end
+    end
+    validate :ends_before_start
+    def ends_before_start
+      if self.starts_at && self.ends_at && self.starts_at >= self.ends_at
+        errors.add(:base, I18n.t("discourse_calendar.post_event.errors.ends_at_before_starts_at"))
+      end
+    end
+    def create_invitees(attrs)
+      timestamp = Time.now
+      attrs.map! do |attr|
+          post_id: self.id,
+          created_at: timestamp,
+          updated_at: timestamp
+        }.merge(attr)
+      end
+      self.invitees.insert_all!(attrs)
+    end
+    def notify_invitees!
+      self.invitees.where(notified: false).each do |invitee|
+        invitee.user.notifications.create!(
GitHub sha: 988b066a
This commit appears in #24 which was merged by jjaffeux.
This looks ripe for SQL injection - can we do some sanitizing on this?
One thing to be careful about here is the objects in ATTRIBUTES are not copied, they are returned by reference. For example name: {} will return that same object literal {} to all calls. Could be the cause of bugs in the future.
Can we import this?
Does this need rel noopener?
It seems peculiar to me that you are storing the raw invites - if the goal is to make it easy to reconstruct the list of who was invited without another query I understand that. But what if an invitee is renamed?
Isn’t this redundant? I thought add_to_serializer only included attributes if plugin.enabled?
I changed it already and I think new version is safe:
Unless I’m misunderstanding how these placeholders conditions work ?
I already changed it, but yes you were right :+1:
I guess that would be better yes.
Done in: FIX: uses the safer rel noopener param · discourse/discourse-calendar@15ca343 · GitHub
I actually don’t need this, I refactored it so I don’t have to create this variable which is not used anywhere else:
Yes rename is an issue, very edge case though, given the amount of renames, people in events, and “short time” of events. I can live with this for V1. One solution could be to add a discourse event on user rename and handle this. We should also handle user bing merged.
The basic idea is that having raw_invitees let’s you be very precise about who should still be in the list. Imagine this scenario: you add group foo and bar. John is in foo and bar groups, Marc is only in bar group.
If you decide to remove the bar group, having this raw_invitees list makes it possible to have a very precise reconciliation of who should be in the invitees.
