FEATURE: Increase daily edit limits proportionally to trust level (#13090)
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index feb1bc0..57dffff 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1582,6 +1582,10 @@ en:
     tl2_additional_likes_per_day_multiplier: "Increase limit of likes per day for tl2 (member) by multiplying with this number"
     tl3_additional_likes_per_day_multiplier: "Increase limit of likes per day for tl3 (regular) by multiplying with this number"
     tl4_additional_likes_per_day_multiplier: "Increase limit of likes per day for tl4 (leader) by multiplying with this number"
+    tl2_additional_edits_per_day_multiplier: "Increase limit of edits per day for tl2 (member) by multiplying with this number"
+    tl3_additional_edits_per_day_multiplier: "Increase limit of edits per day for tl3 (regular) by multiplying with this number"
+    tl4_additional_edits_per_day_multiplier: "Increase limit of edits per day for tl4 (leader) by multiplying with this number"
     num_users_to_silence_new_user: "If a new user's posts get num_spam_flags_to_silence_new_user spam flags from this many different users, hide all their posts and prevent future posting. 0 to disable."
     num_tl3_flags_to_silence_new_user: "If a new user's posts get this many flags from num_tl3_users_to_silence_new_user different trust level 3 users, hide all their posts and prevent future posting. 0 to disable."
     num_tl3_users_to_silence_new_user: "If a new user's posts get num_tl3_flags_to_silence_new_user flags from this many different trust level 3 users, hide all their posts and prevent future posting. 0 to disable."
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 3cc158a..a1538e5 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1746,6 +1746,9 @@ rate_limits:
   tl2_additional_likes_per_day_multiplier: 1.5
   tl3_additional_likes_per_day_multiplier: 2
   tl4_additional_likes_per_day_multiplier: 3
+  tl2_additional_edits_per_day_multiplier: 1.5
+  tl3_additional_edits_per_day_multiplier: 2
+  tl4_additional_edits_per_day_multiplier: 3
   alert_admins_if_errors_per_minute:
     client: true
     default: 0
diff --git a/lib/edit_rate_limiter.rb b/lib/edit_rate_limiter.rb
index 04d095f..d9769f5 100644
--- a/lib/edit_rate_limiter.rb
+++ b/lib/edit_rate_limiter.rb
@@ -3,7 +3,15 @@
 require 'rate_limiter'
 class EditRateLimiter < RateLimiter
   def initialize(user)
-    super(user, "edit-post", SiteSetting.max_edits_per_day, 1.day.to_i)
+    limit = SiteSetting.max_edits_per_day
+    if user.trust_level >= 2
+      multiplier = SiteSetting.get("tl#{user.trust_level}_additional_edits_per_day_multiplier").to_f
+      multiplier = 1.0 if multiplier < 1.0
+      limit = (limit * multiplier).to_i
+    end
+    super(user, "edit-post", limit, 1.day.to_i)
   def build_key(type)
diff --git a/spec/components/post_revisor_spec.rb b/spec/components/post_revisor_spec.rb
index 5d1fe8b..551c2bc 100644
--- a/spec/components/post_revisor_spec.rb
+++ b/spec/components/post_revisor_spec.rb
@@ -485,10 +485,58 @@ describe PostRevisor do
     describe 'rate limiter' do
       fab!(:changed_by) { Fabricate(:coding_horror) }
+      before do
+        RateLimiter.enable
+        RateLimiter.clear_all!
+        SiteSetting.editing_grace_period = 0
+      end
       it "triggers a rate limiter" do
         EditRateLimiter.any_instance.expects(:performed!)
         subject.revise!(changed_by, raw: 'updated body')
+      it "raises error when a user gets rate limited" do
+        SiteSetting.max_edits_per_day = 1
+        user = Fabricate(:user, trust_level: 1)
+        subject.revise!(user, raw: 'body (edited)')
+        expect do
+          subject.revise!(user, raw: 'body (edited twice) ')
+        end.to raise_error(RateLimiter::LimitExceeded)
+      end
+      it "edit limits scale up depending on user's trust level" do
+        SiteSetting.tl2_additional_edits_per_day_multiplier = 2
+        SiteSetting.tl3_additional_edits_per_day_multiplier = 3
+        SiteSetting.tl4_additional_edits_per_day_multiplier = 4
+        user = Fabricate(:user, trust_level: 2)
+        expect { subject.revise!(user, raw: 'body (edited)') }.to_not raise_error
+        expect { subject.revise!(user, raw: 'body (edited twice)') }.to_not raise_error
+        expect do
+          subject.revise!(user, raw: 'body (edited three times) ')
+        user = Fabricate(:user, trust_level: 3)
+        expect { subject.revise!(user, raw: 'body (edited three times)') }.to_not raise_error
+        expect do
+          subject.revise!(user, raw: 'body (edited four times) ')
+        user = Fabricate(:user, trust_level: 4)
+        expect { subject.revise!(user, raw: 'body (edited four times)') }.to_not raise_error
+        expect do
+          subject.revise!(user, raw: 'body (edited five times) ')
+      end
     describe "admin editing a new user's post" do
GitHub sha: 3e0f72f5
This commit appears in #13090 which was approved by SamSaffron. It was merged by AndrewPrigorshnev.
