FEATURE: introduce data-explorer tables (#61)
Instead of using PluginStoreRow we should use plugin-specific models like DataExplorer::Query and DataExplorer::QueryGroup
diff --git a/app/controllers/data_explorer/query_controller.rb b/app/controllers/data_explorer/query_controller.rb
new file mode 100644
index 0000000..c8da839
--- /dev/null
+++ b/app/controllers/data_explorer/query_controller.rb
@@ -0,0 +1,228 @@
+class DataExplorer::QueryController < ::ApplicationController
+  requires_plugin DataExplorer.plugin_name
+  before_action :set_group, only: %i(group_reports_index group_reports_show group_reports_run)
+  before_action :set_query, only: %i(group_reports_show group_reports_run show update)
+  skip_before_action :check_xhr, only: %i(show group_reports_run run)
+  def index
+    queries = DataExplorer::Query.where(hidden: false).order(:last_run_at, :name).includes(:groups).to_a
+    database_queries_ids = DataExplorer::Query.pluck(:id)
+    Queries.default.each do |params|
+      attributes = params.last
+      next if database_queries_ids.include?(attributes["id"])
+      query = DataExplorer::Query.new
+      query.id = attributes["id"]
+      query.sql = attributes["sql"]
+      query.name = attributes["name"]
+      query.description = attributes["description"]
+      query.user_id = Discourse::SYSTEM_USER_ID.to_s
+      queries << query
+    end
+    render_serialized queries, DataExplorer::QuerySerializer, root: 'queries'
+  end
+  def show
+    check_xhr unless params[:export]
+    if params[:export]
+      response.headers['Content-Disposition'] = "attachment; filename=#{@query.slug}.dcquery.json"
+      response.sending_file = true
+    end
+    return raise Discourse::NotFound if !guardian.user_can_access_query?(@query) || @query.hidden
+    render_serialized @query, DataExplorer::QuerySerializer, root: 'query'
+  end
+  def groups
+    render json: Group.all.select(:id, :name), root: false
+  end
+  def group_reports_index
+    return raise Discourse::NotFound unless guardian.user_is_a_member_of_group?(@group)
+    respond_to do |format|
+      format.json do
+          .where(hidden: false)
+          .joins("INNER JOIN data_explorer_query_groups
+                    ON data_explorer_query_groups.query_id = data_explorer_queries.id
+                    AND data_explorer_query_groups.group_id = #{@group.id}")
+        render_serialized(queries, DataExplorer::QuerySerializer, root: 'queries')
+      end
+    end
+  end
+  def group_reports_show
+    return raise Discourse::NotFound if !guardian.group_and_user_can_access_query?(@group, @query) || @query.hidden
+      format.json do
+      end
+    end
+  end
+  def group_reports_run
+    run
+  end
+  def create
+    query = DataExplorer::Query.create!(params.require(:query).permit(:name, :description, :sql).merge(user_id: current_user.id, last_run_at: Time.now))
+    group_ids = params.require(:query)[:group_ids]
+    group_ids&.each do |group_id|
+      query.query_groups.find_or_create_by!(group_id: group_id)
+    end
+    render_serialized query, DataExplorer::QuerySerializer, root: 'query'
+  end
+  def update
+    ActiveRecord::Base.transaction do
+      @query.update!(params.require(:query).permit(:name, :sql, :description).merge(hidden: false))
+      DataExplorer::QueryGroup.where.not(group_id: group_ids).where(query_id: @query.id).delete_all
+        @query.query_groups.find_or_create_by!(group_id: group_id)
+      end
+    end
+  rescue DataExplorer::ValidationError => e
+    render_json_error e.message
+  end
+  def destroy
+    query = DataExplorer::Query.where(id: params[:id]).first_or_initialize
+    query.update!(hidden: true)
+    render json: { success: true, errors: [] }
+  end
+  def schema
+    schema_version = DB.query_single("SELECT max(version) AS tag FROM schema_migrations").first
+    if stale?(public: true, etag: schema_version, template: false)
+      render json: DataExplorer.schema
+    end
+  end
+  # Return value:
+  # success - true/false. if false, inspect the errors value.
+  # errors - array of strings.
+  # params - hash. Echo of the query parameters as executed.
+  # duration - float. Time to execute the query, in milliseconds, to 1 decimal place.
+  # columns - array of strings. Titles of the returned columns, in order.
+  # explain - string. (Optional - pass explain=true in the request) Postgres query plan, UNIX newlines.
+  # rows - array of array of strings. Results of the query. In the same order as 'columns'.
+  def run
+    check_xhr unless params[:download]
+    query = DataExplorer::Query.find(params[:id].to_i)
+    query.update!(last_run_at: Time.now)
+    if params[:download]
+    end
+    params[:params] = params[:_params] if params[:_params] # testing workaround
+    query_params = {}
+    query_params = MultiJson.load(params[:params]) if params[:params]
+    opts = { current_user: current_user.username }
+    opts[:explain] = true if params[:explain] == "true"
+    opts[:limit] =
+      if params[:format] == "csv"
+        if params[:limit].present?
+          limit = params[:limit].to_i
+          limit = DataExplorer::QUERY_RESULT_MAX_LIMIT if limit > DataExplorer::QUERY_RESULT_MAX_LIMIT
+          limit
+        else
+          DataExplorer::QUERY_RESULT_MAX_LIMIT
+        end
+      elsif params[:limit].present?
+        params[:limit] == "ALL" ? "ALL" : params[:limit].to_i
+      end
+    result = DataExplorer.run_query(query, query_params, opts)
+    if result[:error]
+      err = result[:error]
+      # Pretty printing logic
+      err_class = err.class
+      err_msg = err.message
+      if err.is_a? ActiveRecord::StatementInvalid
+        err_class = err.original_exception.class
+        err_msg.gsub!("#{err_class}:", '')
+      else
+        err_msg = "#{err_class}: #{err_msg}"
+      end
+      render json: {
+        success: false,
+        errors: [err_msg]
+      }, status: 422
+    else
+      pg_result = result[:pg_result]
+      cols = pg_result.fields
+        format.json do
+              "attachment; filename=#{query.slug}@#{Slug.for(Discourse.current_hostname, 'discourse')}-#{Date.today}.dcqresult.json"
+          end
+          json = {
+            success: true,
+            errors: [],
+            duration: (result[:duration_secs].to_f * 1000).round(1),
+            result_count: pg_result.values.length || 0,
+            params: query_params,
+            columns: cols,
+            default_limit: DataExplorer::QUERY_RESULT_DEFAULT_LIMIT
+          json[:explain] = result[:explain] if opts[:explain]
+          if !params[:download]
+            relations, colrender = DataExplorer.add_extra_data(pg_result)
+            json[:relations] = relations
+            json[:colrender] = colrender
+          end
+          json[:rows] = pg_result.values
+          render json: json
+        end
+        format.csv do
+            "attachment; filename=#{query.slug}@#{Slug.for(Discourse.current_hostname, 'discourse')}-#{Date.today}.dcqresult.csv"
+          require 'csv'
+          text = CSV.generate do |csv|
+            csv << cols
+            pg_result.values.each do |row|
+              csv << row
+            end
+          end
+          render plain: text
+        end
+      end
+    end
+  end
+  private
+  def set_group
+    @group = Group.find_by(name: params["group_name"])
+  end
+  def set_query
GitHub sha: fe0806eb
This commit appears in #61 which was merged by lis2.
