FEATURE: Make allow_uploaded_avatars accept TL (#14091)
This gives admins more control over who can upload custom profile pictures.
diff --git a/app/assets/javascripts/discourse/app/controllers/avatar-selector.js b/app/assets/javascripts/discourse/app/controllers/avatar-selector.js
index 965207f..83121e0 100644
--- a/app/assets/javascripts/discourse/app/controllers/avatar-selector.js
+++ b/app/assets/javascripts/discourse/app/controllers/avatar-selector.js
@@ -83,10 +83,23 @@ export default Controller.extend(ModalFunctionality, {
-  @discourseComputed()
-  allowAvatarUpload() {
+  siteSettingMatches(value, user) {
+    switch (value) {
+      case "disabled":
+        return false;
+      case "staff":
+        return user.staff;
+      case "admin":
+        return user.admin;
+      default:
+        return user.trust_level >= parseInt(value, 10) || user.staff;
+  @discourseComputed("siteSettings.allow_uploaded_avatars")
+  allowAvatarUpload(allowUploadedAvatars) {
     return (
-      this.siteSettings.allow_uploaded_avatars &&
+      this.siteSettingMatches(allowUploadedAvatars, this.currentUser) &&
       allowsImages(this.currentUser.staff, this.siteSettings)
diff --git a/app/assets/javascripts/discourse/tests/helpers/site-settings.js b/app/assets/javascripts/discourse/tests/helpers/site-settings.js
index 2b86811..d1e7ade 100644
--- a/app/assets/javascripts/discourse/tests/helpers/site-settings.js
+++ b/app/assets/javascripts/discourse/tests/helpers/site-settings.js
@@ -62,7 +62,7 @@ const ORIGINAL_SETTINGS = {
   max_image_width: 690,
   max_image_height: 500,
   allow_profile_backgrounds: true,
-  allow_uploaded_avatars: true,
+  allow_uploaded_avatars: "0",
   tl1_requires_read_posts: 30,
   enable_long_polling: true,
   polling_interval: 3000,
diff --git a/app/controllers/uploads_controller.rb b/app/controllers/uploads_controller.rb
index d2e1619..2048a9f 100644
--- a/app/controllers/uploads_controller.rb
+++ b/app/controllers/uploads_controller.rb
@@ -29,7 +29,7 @@ class UploadsController < ApplicationController
     # 50 characters ought to be enough for the upload type
     type = (params[:upload_type].presence || params[:type].presence).parameterize(separator: "_")[0..50]
-    if type == "avatar" && !me.admin? && (SiteSetting.discourse_connect_overrides_avatar || !SiteSetting.allow_uploaded_avatars)
+    if type == "avatar" && !me.admin? && (SiteSetting.discourse_connect_overrides_avatar || !TrustLevelAndStaffAndDisabledSetting.matches?(SiteSetting.allow_uploaded_avatars, me))
       return render json: failed_json, status: 422
diff --git a/app/controllers/users_controller.rb b/app/controllers/users_controller.rb
index c09b993..83ee6ce 100644
--- a/app/controllers/users_controller.rb
+++ b/app/controllers/users_controller.rb
@@ -1138,7 +1138,7 @@ class UsersController < ApplicationController
     if type.blank? || type == 'system'
       upload_id = nil
-    elsif !SiteSetting.allow_uploaded_avatars
+    elsif !TrustLevelAndStaffAndDisabledSetting.matches?(SiteSetting.allow_uploaded_avatars, user)
     else
       upload_id = params[:upload_id]
diff --git a/app/models/trust_level_and_staff_and_disabled_setting.rb b/app/models/trust_level_and_staff_and_disabled_setting.rb
new file mode 100644
index 0000000..3b1a433
--- /dev/null
+++ b/app/models/trust_level_and_staff_and_disabled_setting.rb
@@ -0,0 +1,32 @@
+class TrustLevelAndStaffAndDisabledSetting < TrustLevelAndStaffSetting
+  def self.valid_value?(val)
+    valid_values.include?(val) || (val.to_i.to_s == val.to_s && valid_values.include?(val.to_i))
+  end
+  def self.valid_values
+    ['disabled'] + TrustLevel.valid_range.to_a + special_groups
+  end
+  def self.translation(value)
+    if value == 'disabled'
+      I18n.t('site_settings.disabled')
+    else
+      super
+    end
+  end
+  def self.matches?(value, user)
+    case value
+    when 'disabled'
+      false
+    when 'staff'
+      user.staff?
+    when 'admin'
+      user.admin?
+    else
+      user.has_trust_level?(value.to_i) || user.staff?
+    end
+  end
+end
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index f98b153..228e1aa 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1450,6 +1450,7 @@ en:
     watched_word_regexp_error: "The regular expression for '%{action}' watched words is invalid. Please check your <a href='%{base_path}/admin/customize/watched_words'>Watched Word settings</a>, or disable the 'watched words regular expressions' site setting."
   site_settings:
+    disabled: "disabled"
     display_local_time_in_user_card: "Display the local time based on a user's timezone when their user card is opened."
     censored_words: "Words that will be automatically replaced with &#9632;&#9632;&#9632;&#9632;"
     delete_old_hidden_posts: "Auto-delete any hidden posts that stay hidden for more than 30 days."
diff --git a/config/site_settings.yml b/config/site_settings.yml
index e9f63af..d08c5bc 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1365,7 +1365,8 @@ files:
   automatically_download_gravatars: true
     client: true
-    default: true
+    default: "0"
+    enum: "TrustLevelAndStaffAndDisabledSetting"
   default_avatars:
     default: ""
     type: url_list
diff --git a/db/migrate/20210819152920_change_allow_uploaded_avatars.rb b/db/migrate/20210819152920_change_allow_uploaded_avatars.rb
index 0000000..6556d6c
--- /dev/null
+++ b/db/migrate/20210819152920_change_allow_uploaded_avatars.rb
@@ -0,0 +1,19 @@
+class ChangeAllowUploadedAvatars < ActiveRecord::Migration[6.1]
+  def up
+    execute <<~SQL
+      UPDATE site_settings
+      SET data_type = 7, value = (CASE WHEN value = 'f' THEN 'disabled' ELSE '0' END)
+      WHERE name = 'allow_uploaded_avatars'
+    SQL
+  end
+  def down
+    execute <<~SQL
+      SET data_type = 5, value = (CASE WHEN value = 'disabled' THEN 'f' ELSE 't' END)
+    SQL
+  end
+end
diff --git a/lib/composer_messages_finder.rb b/lib/composer_messages_finder.rb
index 14c9891..06ce896 100644
--- a/lib/composer_messages_finder.rb
+++ b/lib/composer_messages_finder.rb
@@ -78,7 +78,7 @@ class ComposerMessagesFinder
     # - "disable avatar education message" is enabled
     # - "sso overrides avatar" is enabled
     # - "allow uploaded avatars" is disabled
-    return if SiteSetting.disable_avatar_education_message || SiteSetting.discourse_connect_overrides_avatar || !SiteSetting.allow_uploaded_avatars
+    return if SiteSetting.disable_avatar_education_message || SiteSetting.discourse_connect_overrides_avatar || !TrustLevelAndStaffAndDisabledSetting.matches?(SiteSetting.allow_uploaded_avatars, @user)
     # If we got this far, log that we've nagged them about the avatar
     UserHistory.create!(action: UserHistory.actions[:notified_about_avatar], target_user_id: @user.id)
diff --git a/spec/components/composer_messages_finder_spec.rb b/spec/components/composer_messages_finder_spec.rb
index 855b187..15bb3e8 100644
--- a/spec/components/composer_messages_finder_spec.rb
+++ b/spec/components/composer_messages_finder_spec.rb
@@ -144,7 +144,7 @@ describe ComposerMessagesFinder do
     it "doesn't notify users if 'allow_uploaded_avatars' setting is disabled" do
-      SiteSetting.allow_uploaded_avatars = false
+      SiteSetting.allow_uploaded_avatars = 'disabled'
       expect(finder.check_avatar_notification).to be_blank
diff --git a/spec/requests/uploads_controller_spec.rb b/spec/requests/uploads_controller_spec.rb
index c14e3f3..737c992 100644
--- a/spec/requests/uploads_controller_spec.rb
+++ b/spec/requests/uploads_controller_spec.rb
@@ -126,7 +126,7 @@ describe UploadsController do
       it 'ensures allow_uploaded_avatars is enabled when uploading an avatar' do
GitHub sha: ff367e22fbd1744bd52ae1f3932c4c3965b39587
This commit appears in #14091 which was approved by eviltrout. It was merged by nbianca.
