@eviltrout I requested a review from you here because I added this part to helpers/component-test.js
this.registry.register("message-bus:main", MessageBus, {
instantiate: false,
this.registry.injection("component", "messageBus", "message-bus:main");
I have done this because the widget subscribes to a message bus channel and I need to simulate this channel receiving a message in my test:
// Mimic a messagebus message
MessageBus.callbacks
.filterBy("channel", "/global/asset-version")
.map((c) => c.func("somenewversion"));
I am not really sure if the message bus was intentionally left out as a service to inject into the tests? I am unfamiliar with how this stuff works in Ember/our setup.
That won’t fly with almost all themes, forcing theme authors to override .software-update-prompt
. It would be better to position the prompt relative to the header.
Oh, and looking at the mobile screenshot I see the dreaded content bleed issue, visible between the prompt and the header. I think it’s a browser bug, floating point precision error or something, but it looks like it’s here to stay so we can work around it by displaying the prompt behind the header (z-index
) and stretching it slightly in the upward direction (so: moving it a pixel or two higher and increasing top padding the same amount)
I’m not sure how I feel about having it in the DOM at all times But I guess it makes animating it easier.
It definitely was not intentional. If it’s present in the application it should be present in tests.
Yeah I think both of these issues would be solved by moving the prompt to be right after .d-header
(but still within .d-header-wrap
). @martin-brennan if you can move it there I can go ahead and take care of the styling
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
