FEATURE: multiple use invite links (PR #9813)
This commit allows Admins to create an invite link that can be used multiple times.
Creating Invite Link:
Screen Shot 2020-05-18 at 10 26 11
Invite Link listing page:
Screen Shot 2020-05-18 at 10 26 18
Invite Link redemption page:
Screen Shot 2020-05-18 at 12 09 47
Invite “Redeemed” tab showing all the accepted invites:
Screen Shot 2020-05-18 at 12 10 51
GitHub
This pull request introduces 4 alerts when merging bdd46e1288b7a1c0dc4284122fe15a8fc4cc73f1 into 862773ec83756a2deb6beaabbcb16756a98595f9 - view on LGTM.com
new alerts:
  • 4 for Unused variable, import, function or class
This pull request introduces 2 alerts when merging aa5856d542c839cc362983dc278cdecd7465c855 into 862773ec83756a2deb6beaabbcb16756a98595f9 - view on LGTM.com
new alerts:
  • 2 for Unused variable, import, function or class
missing a space here, will fail linting
would prefer readOnly instead of all the alias here
should be set there’s only one property
        .then(result => {
do we need a get here ?
        .catch(e => {
Why do you need a native array here ?
Also I would prefer this to be null, and the array initiated in init()
you can replace all of this by using or()
          .then(result => {
    ).then(invites => this.set("model", invites));
do we need the get here ? if currentUser is null having a get won’t save you from an error
maybe we should have a constant for “links” here
        confirm => {
        ).then(invite_model => {
can you try to remove this inline style while you are at it please ?
do we need email=null here ? why not just removed the email property
everything else is on one line and this if is done on 3 ? :stuck_out_tongue:
