FEATURE: Navigate to an approved queued topic from the review queue. (#12841)
Admins can visit an approved queued topic from the review queue by clicking their title. We no longer store the created post and topic ids in the reviewable’s payload object. Instead, we set the topic_id and target_id attributes.
diff --git a/app/models/reviewable_queued_post.rb b/app/models/reviewable_queued_post.rb
index 8d108c6..1055594 100644
--- a/app/models/reviewable_queued_post.rb
+++ b/app/models/reviewable_queued_post.rb
@@ -83,8 +83,10 @@ class ReviewableQueuedPost < Reviewable
       return create_result(:failure) { |r| r.errors = creator.errors }
-    payload['created_post_id'] = created_post.id
-    payload['created_topic_id'] = created_post.topic_id unless topic_id
+    self.target = created_post
+    if topic_id.nil?
+      self.topic_id = created_post.topic_id
+    end
     save
     UserSilencer.unsilence(created_by, performed_by) if created_by.silenced?
diff --git a/db/migrate/20210426193009_move_approved_queued_posts_topic_and_post_data.rb b/db/migrate/20210426193009_move_approved_queued_posts_topic_and_post_data.rb
new file mode 100644
index 0000000..b2f548e
--- /dev/null
+++ b/db/migrate/20210426193009_move_approved_queued_posts_topic_and_post_data.rb
@@ -0,0 +1,18 @@
+class MoveApprovedQueuedPostsTopicAndPostData < ActiveRecord::Migration[6.1]
+  def up
+    DB.query_single <<~SQL
+      UPDATE reviewables r
+      SET topic_id = (payload->>'created_topic_id')::int, target_id = (payload->>'created_post_id')::int, target_type = 'Post'
+      WHERE r.type = 'ReviewableQueuedPost' AND r.status = 1
+      AND (r.payload->>'created_topic_id') IS NOT NULL
+      AND (r.payload->>'created_post_id') IS NOT NULL
+      AND topic_id IS NULL
+      AND target_id IS NULL
+    SQL
+  end
+  def down
+  end
+end
diff --git a/spec/models/reviewable_queued_post_spec.rb b/spec/models/reviewable_queued_post_spec.rb
index 7312544..97e5b61 100644
--- a/spec/models/reviewable_queued_post_spec.rb
+++ b/spec/models/reviewable_queued_post_spec.rb
@@ -61,7 +61,7 @@ RSpec.describe ReviewableQueuedPost, type: :model do
           expect(result.created_post.custom_fields['hello']).to eq('world')
           expect(result.created_post_topic).to eq(topic)
           expect(result.created_post.user).to eq(reviewable.created_by)
-          expect(reviewable.payload['created_post_id']).to eq(result.created_post.id)
+          expect(reviewable.target_id).to eq(result.created_post.id)
           expect(Topic.count).to eq(topic_count)
           expect(Post.count).to eq(post_count + 1)
@@ -183,8 +183,8 @@ RSpec.describe ReviewableQueuedPost, type: :model do
       expect(result.created_post).to be_valid
       expect(result.created_post_topic).to be_present
       expect(result.created_post_topic).to be_valid
-      expect(reviewable.payload['created_topic_id']).to eq(result.created_post_topic.id)
+      expect(reviewable.topic_id).to eq(result.created_post_topic.id)
       expect(Topic.count).to eq(topic_count + 1)
GitHub sha: 83dd47f0
This commit appears in #12841 which was approved by eviltrout. It was merged by romanrizzi.
