FEATURE: New post editing period for >= tl2 users (#8070)
  • FEATURE: Add tl2 threshold for editing new posts
  • Adds a new setting and for tl2 editing posts (30 days same as old value)
  • Sets the tl0/tl1 editing period as 1 day
  • FIX: Spec uses wrong setting
  • Fix site setting on guardian spec
  • FIX: post editing period specs
  • Avoid shared examples
  • Use update_columns to avoid callbacks on user during tests
diff --git a/app/controllers/posts_controller.rb b/app/controllers/posts_controller.rb
index 03221e6..d5a9a12 100644
--- a/app/controllers/posts_controller.rb
+++ b/app/controllers/posts_controller.rb
@@ -204,7 +204,7 @@ class PostsController < ApplicationController
     if !guardian.public_send("can_edit?", post) &&
        post.user_id == current_user.id &&
-       post.edit_time_limit_expired?
+       post.edit_time_limit_expired?(current_user)
       return render_json_error(I18n.t('too_late_to_edit'))
diff --git a/app/models/concerns/limited_edit.rb b/app/models/concerns/limited_edit.rb
index cbe1554..bfd2139 100644
--- a/app/models/concerns/limited_edit.rb
+++ b/app/models/concerns/limited_edit.rb
@@ -3,11 +3,22 @@
 module LimitedEdit
   extend ActiveSupport::Concern
-  def edit_time_limit_expired?
-    if created_at && SiteSetting.post_edit_time_limit.to_i > 0
-      created_at < SiteSetting.post_edit_time_limit.to_i.minutes.ago
+  def edit_time_limit_expired?(user)
+    time_limit = user_time_limit(user)
+    if created_at && time_limit > 0
+      created_at < time_limit.minutes.ago
     else
       false
+  private
+  def user_time_limit(user)
+    if user.trust_level < 2
+      SiteSetting.post_edit_time_limit.to_i
+    else
+      SiteSetting.tl2_post_edit_time_limit.to_i
+    end
+  end
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 60f20e5..ff522b0 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1361,7 +1361,8 @@ en:
     editing_grace_period_max_diff: "Maximum number of character changes allowed in editing grace period, if more changed store another post revision (trust level 0 and 1)"
     editing_grace_period_max_diff_high_trust: "Maximum number of character changes allowed in editing grace period, if more changed store another post revision (trust level 2 and up)"
     staff_edit_locks_post: "Posts will be locked from editing if they are edited by staff members"
-    post_edit_time_limit: "The author can edit their post for (n) minutes after posting. Set to 0 for forever."
+    post_edit_time_limit: "A tl0 or tl1 author can edit their post for (n) minutes after posting. Set to 0 for forever."
+    tl2_post_edit_time_limit: "A tl2 author can edit their post for (n) minutes after posting. Set to 0 for forever."
     edit_history_visible_to_public: "Allow everyone to see previous versions of an edited post. When disabled, only staff members can view."
     delete_removed_posts_after: "Posts removed by the author will be automatically deleted after (n) hours. If set to 0, posts will be deleted immediately."
     max_image_width: "Maximum thumbnail width of images in a post"
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 67683bc..c1a6cbf 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -700,6 +700,9 @@ posting:
     type: category
     default: ""
+    default: 1440
+    max: 10080
     default: 43200
     max: 525600
diff --git a/lib/guardian/post_guardian.rb b/lib/guardian/post_guardian.rb
index a8344e9..25c46de 100644
--- a/lib/guardian/post_guardian.rb
+++ b/lib/guardian/post_guardian.rb
@@ -158,7 +158,7 @@ module PostGuardian
         return true
-      return !post.edit_time_limit_expired?
+      return !post.edit_time_limit_expired?(@user)
     false
@@ -238,7 +238,7 @@ module PostGuardian
     if @user.has_trust_level?(SiteSetting.min_trust_to_allow_self_wiki) && is_my_own?(post)
       return false if post.hidden?
     false
diff --git a/lib/guardian/topic_guardian.rb b/lib/guardian/topic_guardian.rb
index e171d32..89f5fe6 100644
--- a/lib/guardian/topic_guardian.rb
+++ b/lib/guardian/topic_guardian.rb
@@ -106,7 +106,7 @@ module TopicGuardian
     return false if topic.archived
     is_my_own?(topic) &&
-      !topic.edit_time_limit_expired? &&
+      !topic.edit_time_limit_expired?(user) &&
       !Post.where(topic_id: topic.id, post_number: 1).where.not(locked_by_id: nil).exists?
diff --git a/spec/components/guardian_spec.rb b/spec/components/guardian_spec.rb
index 926bf31..0dddab7 100644
--- a/spec/components/guardian_spec.rb
+++ b/spec/components/guardian_spec.rb
@@ -1389,32 +1389,65 @@ describe Guardian do
         expect(Guardian.new(post.user).can_edit?(post)).to be_truthy
-      context 'post is older than post_edit_time_limit' do
-        let(:old_post) { build(:post, topic: topic, user: topic.user, created_at: 6.minutes.ago) }
+      describe 'post edit time limits' do
+        context 'post is older than post_edit_time_limit' do
+          let(:old_post) { build(:post, topic: topic, user: topic.user, created_at: 6.minutes.ago) }
-        before do
-          SiteSetting.post_edit_time_limit = 5
-        end
+          before do
+            topic.user.update_columns(trust_level:  1)
+            SiteSetting.post_edit_time_limit = 5
+          end
-        it 'returns false to the author of the post' do
-          expect(Guardian.new(old_post.user).can_edit?(old_post)).to be_falsey
-        end
+          it 'returns false to the author of the post' do
+            expect(Guardian.new(old_post.user).can_edit?(old_post)).to be_falsey
+          end
-        it 'returns true as a moderator' do
-          expect(Guardian.new(moderator).can_edit?(old_post)).to eq(true)
-        end
+          it 'returns true as a moderator' do
+            expect(Guardian.new(moderator).can_edit?(old_post)).to eq(true)
+          end
-        it 'returns true as an admin' do
-          expect(Guardian.new(admin).can_edit?(old_post)).to eq(true)
-        end
+          it 'returns true as an admin' do
+            expect(Guardian.new(admin).can_edit?(old_post)).to eq(true)
+          end
+          it 'returns false for another regular user trying to edit your post' do
+            expect(Guardian.new(coding_horror).can_edit?(old_post)).to be_falsey
+          end
-        it 'returns false for another regular user trying to edit your post' do
-          expect(Guardian.new(coding_horror).can_edit?(old_post)).to be_falsey
+          it 'returns true for another regular user trying to edit a wiki post' do
+            old_post.wiki = true
+            expect(Guardian.new(coding_horror).can_edit?(old_post)).to be_truthy
+          end
-        it 'returns true for another regular user trying to edit a wiki post' do
-          old_post.wiki = true
-          expect(Guardian.new(coding_horror).can_edit?(old_post)).to be_truthy
+        context 'post is older than tl2_post_edit_time_limit' do
+          let(:old_post) { build(:post, topic: topic, user: topic.user, created_at: 12.minutes.ago) }
+          before do
+            topic.user.update_columns(trust_level: 2)
+            SiteSetting.tl2_post_edit_time_limit = 10
+          end
+          end
+          end
+          end
+          end
+          end
@@ -2854,7 +2887,7 @@ describe Guardian do
GitHub sha: 6bbd8306
