FEATURE: Optional detailed performance logging for Sidekiq jobs (#7091)
approved
#1
By default, this does nothing. Two environment variables are available:
  • DISCOURSE_LOG_SIDEKIQ
    Set to "1" to enable logging. This will log all completed jobs to log/rails/sidekiq.log, along with various db/redis/network statistics. This is useful to track down poorly performing jobs.
  • DISCOURSE_LOG_SIDEKIQ_INTERVAL
    (seconds) Check running jobs periodically, and log their current duration. They will appear in the logs with status:pending. This is useful to track down jobs which take a long time, then crash sidekiq before completing.
diff --git a/app/jobs/base.rb b/app/jobs/base.rb
index a7d2399..4743194 100644
--- a/app/jobs/base.rb
+++ b/app/jobs/base.rb
@@ -16,35 +16,102 @@ module Jobs
   class Base
+    class JobInstrumenter
+      def initialize(job_class:, opts:, db:)
+        return unless enabled?
+        @data = {}
+        @data["hostname"] = `hostname`.strip # Hostname
+        @data["pid"] = Process.pid # Pid
+        @data["database"] = db # DB name - multisite db name it ran on
+        @data["job_name"] = job_class.name # Job Name - eg: Jobs::AboutStats
+        @data["job_type"] = job_class.try(:scheduled?) ? "scheduled" : "regular" # Job Type - either s for scheduled or r for regular
+        @data["opts"] = opts # Params - json encoded params for the job
+        @data["status"] = 'pending'
+        @start_timestamp = Process.clock_gettime(Process::CLOCK_MONOTONIC)
+        self.class.ensure_interval_logging!
+        @@active_jobs ||= []
+        @@active_jobs << self
+        MethodProfiler.ensure_discourse_instrumentation!
+        MethodProfiler.start
+      end
-    class Instrumenter
+      def stop(exception:)
-      def self.stats
-        Thread.current[:db_stats] ||= Stats.new
-      end
+        profile = MethodProfiler.stop
-      class Stats
-        attr_accessor :query_count, :duration_ms
+        @@active_jobs.delete(self)
-        def initialize
-          @query_count = 0
-          @duration_ms = 0
+        @data["duration"] = profile[:total_duration] # Duration - length in seconds it took to run
+        @data["sql_duration"] = profile.dig(:sql, :duration) || 0 # Sql Duration (s)
+        @data["sql_calls"] = profile.dig(:sql, :calls) || 0 # Sql Statements - how many statements ran
+        @data["redis_duration"] = profile.dig(:redis, :duration) || 0 # Redis Duration (s)
+        @data["redis_calls"] = profile.dig(:redis, :calls) || 0 # Redis commands
+        @data["net_duration"] = profile.dig(:net, :duration) || 0 # Redis Duration (s)
+        @data["net_calls"] = profile.dig(:net, :calls) || 0 # Redis commands
+        if exception.present?
+          @data["exception"] = exception # Exception - if job fails a json encoded exception
+          @data["status"] = 'failed'
+        else
+          @data["status"] = 'success' # Status - fail, success, pending
+        write_to_log
-      def call(name, start, finish, message_id, values)
-        stats = Instrumenter.stats
-        stats.query_count += 1
-        stats.duration_ms += (((finish - start).to_f) * 1000).to_i
+      def self.raw_log(message)
+        @@logger ||= Logger.new("#{Rails.root}/log/sidekiq.log")
+        @@log_queue ||= Queue.new
+        unless @log_thread&.alive?
+          @@log_thread = Thread.new do
+            begin
+              loop { @@logger << @@log_queue.pop }
+            rescue Exception => e
+              Discourse.warn_exception(e, message: "Sidekiq logging thread terminated unexpectedly")
+            end
+          end
+        end
+        @@log_queue.push(message)
-    end
-    include Sidekiq::Worker
+      def current_duration
+        Process.clock_gettime(Process::CLOCK_MONOTONIC) - @start_timestamp
+      end
+      def write_to_log
+        @data["@timestamp"] = Time.now
+        @data["duration"] = current_duration if @data["status"] == "pending"
+        self.class.raw_log("#{@data.to_json}\n")
+      end
+      def enabled?
+        ENV["DISCOURSE_LOG_SIDEKIQ"] == "1"
+      end
-    def initialize
-      @db_duration = 0
+      def self.ensure_interval_logging!
+        interval = ENV["DISCOURSE_LOG_SIDEKIQ_INTERVAL"]
+        return if !interval
+        @@interval_thread ||= Thread.new do
+          begin
+            loop do
+              sleep interval.to_i
+              @@active_jobs.each { |j| j.write_to_log if j.current_duration > interval }
+            end
+            Discourse.warn_exception(e, message: "Sidekiq interval logging thread terminated unexpectedly")
+          end
+        end
+      end
+    include Sidekiq::Worker
     def log(*args)
       args.each do |arg|
         Rails.logger.info "#{Time.now.to_formatted_s(:db)}: [#{self.class.name.upcase}] #{arg}"
@@ -81,16 +148,7 @@ module Jobs
       @db_duration || 0
-    def ensure_db_instrumented
-      @@instrumented ||= begin
-        ActiveSupport::Notifications.subscribe('sql.active_record', Instrumenter.new)
-        true
-      end
-    end
     def perform(*args)
-      total_db_time = 0
-      ensure_db_instrumented
       opts = args.extract_options!.with_indifferent_access
       if SiteSetting.queue_jobs?
@@ -125,6 +183,7 @@ module Jobs
           exception = {}
           RailsMultisite::ConnectionManagement.with_connection(db) do
+            job_instrumenter = JobInstrumenter.new(job_class: self.class, opts: opts, db: db)
             begin
               I18n.locale = SiteSetting.default_locale || "en"
               I18n.ensure_all_loaded!
@@ -144,7 +203,7 @@ module Jobs
               exception[:message] = "While establishing database connection to #{db}"
               exception[:other] = { problem_db: db }
             ensure
-              total_db_time += Instrumenter.stats.duration_ms
+              job_instrumenter.stop(exception: exception)
@@ -164,7 +223,6 @@ module Jobs
       nil
     ensure
       ActiveRecord::Base.connection_handler.clear_active_connections!
-      @db_duration = total_db_time
diff --git a/lib/method_profiler.rb b/lib/method_profiler.rb
index f624ea8..e1398e0 100644
--- a/lib/method_profiler.rb
+++ b/lib/method_profiler.rb
@@ -61,4 +61,26 @@ class MethodProfiler
     data
+  def self.ensure_discourse_instrumentation!
+    @@instrumentation_setup ||= begin
+      MethodProfiler.patch(PG::Connection, [
+        :exec, :async_exec, :exec_prepared, :send_query_prepared, :query, :exec_params
+      ], :sql)
+      MethodProfiler.patch(Redis::Client, [
+        :call, :call_pipeline
+      ], :redis)
+      MethodProfiler.patch(Net::HTTP, [
+        :request
+      ], :net, no_recurse: true)
+      MethodProfiler.patch(Excon::Connection, [
+        :request
+      ], :net)
+      true
+    end
+  end
diff --git a/lib/middleware/request_tracker.rb b/lib/middleware/request_tracker.rb
index 33a5fa1..e8af3b5 100644
--- a/lib/middleware/request_tracker.rb
+++ b/lib/middleware/request_tracker.rb
@@ -15,26 +15,7 @@ class Middleware::RequestTracker
   #   # do stuff with env and data
   # end
   def self.register_detailed_request_logger(callback)
-    unless @patched_instrumentation
-      MethodProfiler.patch(PG::Connection, [
-        :exec, :async_exec, :exec_prepared, :send_query_prepared, :query, :exec_params
-      ], :sql)
-      MethodProfiler.patch(Redis::Client, [
-        :call, :call_pipeline
-      ], :redis)
-      MethodProfiler.patch(Net::HTTP, [
-        :request
-      ], :net, no_recurse: true)
-      MethodProfiler.patch(Excon::Connection, [
-        :request
-      ], :net)
-      @patched_instrumentation = true
-    end
     (@@detailed_request_loggers ||= []) << callback
GitHub sha: 8963f1af
Approved #2
#3
