FEATURE: Per-member counts in group assignment summary (#80)
diff --git a/app/controllers/discourse_assign/assign_controller.rb b/app/controllers/discourse_assign/assign_controller.rb
index 41177cc..b9775d9 100644
--- a/app/controllers/discourse_assign/assign_controller.rb
+++ b/app/controllers/discourse_assign/assign_controller.rb
@@ -124,6 +124,30 @@ module DiscourseAssign
       render json: { topics: serialize_data(topics, AssignedTopicSerializer) }
+    def group_members
+      limit = (params[:limit] || 50).to_i
+      offset = params[:offset].to_i
+      raise Discourse::InvalidParameters.new(:limit) if limit < 0 || limit > 1000
+      raise Discourse::InvalidParameters.new(:offset) if offset < 0
+      raise Discourse::NotFound.new if !params[:group_name].present?
+      group = Group.find_by(name: params[:group_name])
+      guardian.ensure_can_see_group_members!(group)
+      members = User
+        .joins("LEFT OUTER JOIN group_users g on users.id=g.user_id LEFT OUTER JOIN user_options uo on uo.user_id=users.id LEFT OUTER JOIN topic_custom_fields tcf ON tcf.value::int = users.id")
+        .where("tcf.name = 'assigned_to_id' AND g.group_id=? AND (users.id > 0)", group.id)
+        .order('COUNT(users.id) DESC')
+        .group('users.id')
+        .select('users.*, COUNT(users.id) as "assignments_count"')
+        .limit(limit)
+        .offset(offset)
+      render json: { members: serialize_data(members, GroupUserAssignedSerializer) }
+    end
     private
     def translate_failure(reason, user)
diff --git a/app/serializers/group_user_assigned_serializer.rb b/app/serializers/group_user_assigned_serializer.rb
new file mode 100644
index 0000000..b670e5c
--- /dev/null
+++ b/app/serializers/group_user_assigned_serializer.rb
@@ -0,0 +1,12 @@
+class GroupUserAssignedSerializer < BasicUserSerializer
+  attributes :assignments_count,
+             :username_lower
+  def include_assignments_count
+    object.can_assign?
+  end
+end
diff --git a/assets/javascripts/discourse-assign/controllers/group-assignments.js.es6 b/assets/javascripts/discourse-assign/controllers/group-assignments.js.es6
index f77a18a..1ecbd4a 100644
--- a/assets/javascripts/discourse-assign/controllers/group-assignments.js.es6
+++ b/assets/javascripts/discourse-assign/controllers/group-assignments.js.es6
@@ -1,31 +1,33 @@
 import { inject as service } from "@ember/service";
 import Controller, { inject as controller } from "@ember/controller";
+import { ajax } from "discourse/lib/ajax";
 export default Controller.extend({
   router: service(),
   application: controller(),
   loading: false,
+  offset: 0,
   findMembers(refresh) {
-    if (this.loading || !this.model) {
+    if (refresh) {
+      this.set("members", this.model.members);
       return;
-    if (!refresh && this.model.members.length >= this.model.user_count) {
-      this.set("application.showFooter", true);
+    if (this.loading || !this.model) {
       return;
-    this.set("loading", true);
-    this.model
-      .findMembers({ order: "", asc: true, filter: null }, refresh)
-      .finally(() => {
-        this.setProperties({
-          "application.showFooter":
-            this.model.members.length >= this.model.user_count,
-          loading: false
+    if (this.model.members.length >= this.offset + 50) {
+      this.set("loading", true);
+      this.set("offset", this.offset + 50);
+      ajax(`/assign/members/${this.groupName}?offset=${this.offset}`).then(
+        result => {
+          this.members.pushObjects(result.members);
+          this.set("loading", false);
   actions: {
diff --git a/assets/javascripts/discourse-assign/routes/group-assignments.js.es6 b/assets/javascripts/discourse-assign/routes/group-assignments.js.es6
index c70a634..fd90774 100644
--- a/assets/javascripts/discourse-assign/routes/group-assignments.js.es6
+++ b/assets/javascripts/discourse-assign/routes/group-assignments.js.es6
@@ -1,14 +1,16 @@
 import Route from "@ember/routing/route";
 export default Route.extend({
   model() {
-    return this.modelFor("group");
+    return ajax(`/assign/members/${this.modelFor("group").get("name")}`);
   setupController(controller, model) {
     controller.setProperties({
       model,
-      showing: "members"
+      members: [],
+      groupName: this.modelFor("group").get("name")
     controller.findMembers(true);
diff --git a/assets/javascripts/discourse/components/group-assignments-filter.js.es6 b/assets/javascripts/discourse/components/group-assignments-filter.js.es6
index 0ce9cfe..873ac3d 100644
--- a/assets/javascripts/discourse/components/group-assignments-filter.js.es6
+++ b/assets/javascripts/discourse/components/group-assignments-filter.js.es6
@@ -7,12 +7,12 @@ export default Component.extend({
   @discourseComputed(
     "siteSettings.prioritize_username_in_ux",
     "filter.username",
-    "filter.displayName"
+    "filter.name"
-  displayName(prioritize_username_in_ux, username, displayName) {
+  displayName(prioritize_username_in_ux, username, name) {
     if (prioritize_username_in_ux) {
-      return username;
+      return username.trim();
-    return displayName;
+    return (name || username).trim();
diff --git a/assets/javascripts/discourse/templates/components/group-assignments-filter.hbs b/assets/javascripts/discourse/templates/components/group-assignments-filter.hbs
index e052f57..be45773 100644
--- a/assets/javascripts/discourse/templates/components/group-assignments-filter.hbs
+++ b/assets/javascripts/discourse/templates/components/group-assignments-filter.hbs
@@ -1,6 +1,6 @@
 {{#if show-avatar}}
   {{#link-to "group.assignments.show" filter.username_lower}}
-    {{avatar filter avatarTemplatePath="avatar_template" usernamePath="username" imageSize="small"}} {{displayName}}
+    {{avatar filter avatarTemplatePath="avatar_template" usernamePath="username" imageSize="small"}} {{displayName}} ({{filter.assignments_count}})
   {{/link-to}}
 {{else}}
   {{#link-to "group.assignments.show" filter}}
diff --git a/assets/javascripts/discourse/templates/group/assignments.hbs b/assets/javascripts/discourse/templates/group/assignments.hbs
index 683ecda..ff29d89 100644
--- a/assets/javascripts/discourse/templates/group/assignments.hbs
+++ b/assets/javascripts/discourse/templates/group/assignments.hbs
@@ -2,7 +2,7 @@
   {{#mobile-nav class="activity-nav" desktopClass="action-list activity-list nav-stacked" currentPath=router._router.currentPath}}
     {{#load-more selector=".activity-nav li" action=(action "loadMore")}}
       {{group-assignments-filter show-avatar=false filter="everyone" routeType=route_type}}
-      {{#each model.members as |member|}}
+      {{#each members as |member|}}
         {{group-assignments-filter show-avatar=true filter=member routeType=route_type}}
       {{/each}}
       {{conditional-loading-spinner condition=loading}}
diff --git a/config/routes.rb b/config/routes.rb
index 575166e..02ddb36 100644
--- a/config/routes.rb
+++ b/config/routes.rb
@@ -6,4 +6,5 @@ DiscourseAssign::Engine.routes.draw do
   put "/unassign" => "assign#unassign"
   get "/suggestions" => "assign#suggestions"
   get "/assigned" => "assign#assigned"
+  get "/members/:group_name" => "assign#group_members"
index e95850a..f7d8c7d 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -253,6 +253,8 @@ after_initialize do
     page = (params[:page].to_i || 0).to_i
     group = Group.find_by("name = ?", params[:groupname])
     raise Discourse::NotFound unless group
     raise Discourse::InvalidAccess unless current_user.can_assign?
diff --git a/spec/requests/assign_controller_spec.rb b/spec/requests/assign_controller_spec.rb
index 5737f64..f68437c 100644
--- a/spec/requests/assign_controller_spec.rb
GitHub sha: 816f3c0e
This commit appears in #80 which was merged by davidtaylorhq.
