FEATURE: permanently delete a private message (#79)
Previously we added a future to set a time for permanent deletion for encrypted messages.
This feature allows user to permanently delete post even if the timer was not set. When the user clicks the delete button, we inform that message will be permanently deleted and create a timer for 1 minute. It allows the user to rollback if clicked by mistake.
diff --git a/app/controllers/encrypted_post_timers_controller.rb b/app/controllers/encrypted_post_timers_controller.rb
new file mode 100644
index 0000000..b2fc6b7
--- /dev/null
+++ b/app/controllers/encrypted_post_timers_controller.rb
@@ -0,0 +1,34 @@
+class DiscourseEncrypt::EncryptedPostTimersController < ApplicationController
+  def create
+    delete_at = 1.minutes.from_now
+    Array.wrap(params[:post_id]).each do |post_id|
+      create_for_post(post_id, delete_at)
+    end
+    render json: { delete_at: delete_at }
+  end
+  def destroy
+    post = Post.with_deleted.find(params[:post_id])
+    encrypted_post_timer = EncryptedPostTimer.find_by(post: post)
+    return unless encrypted_post_timer
+    if post.is_first_post?
+      topic = Topic.with_deleted.find(post.topic_id)
+      guardian.ensure_can_recover_topic!(topic)
+    else
+      guardian.ensure_can_recover_post!(post)
+    end
+    encrypted_post_timer.destroy!
+  end
+  private
+  def create_for_post(post_id, delete_at)
+    post = Post.find(post_id)
+    return unless post.is_encrypted?
+    guardian.ensure_can_delete!(post.is_first_post? ? post.topic : post)
+    EncryptedPostTimer.create!(post: post, delete_at: delete_at)
+  end
+end
diff --git a/app/jobs/scheduled/encrypted_post_timer_evaluator.rb b/app/jobs/scheduled/encrypted_post_timer_evaluator.rb
index 99425c4..148e0b2 100644
--- a/app/jobs/scheduled/encrypted_post_timer_evaluator.rb
+++ b/app/jobs/scheduled/encrypted_post_timer_evaluator.rb
@@ -8,7 +8,9 @@ module Jobs
       EncryptedPostTimer.pending.find_each do |encrypted_post_timer|
         ActiveRecord::Base.transaction do
           encrypted_post_timer.touch(:destroyed_at)
-          next if !encrypted_post_timer.post&.persisted?
+          next if posts_to_delete(encrypted_post_timer).blank?
+          next unless @topic
+          @topic.update_columns(deleted_at: nil)
           posts_to_delete(encrypted_post_timer).each do |post|
             next if !post&.persisted?
             PostDestroyer.new(post.user, post, permanent: true).destroy
@@ -18,7 +20,11 @@ module Jobs
     def posts_to_delete(encrypted_post_timer)
-      encrypted_post_timer.post.is_first_post? ? encrypted_post_timer.post.topic.posts.with_deleted.order(created_at: :desc) : [encrypted_post_timer.post]
+      @post ||= Post.with_deleted.find_by(id: encrypted_post_timer.post_id)
+      return [] unless @post
+      @topic ||= Topic.with_deleted.find_by(id: @post.topic_id)
+      @posts_to_delete ||= @post&.is_first_post? ? @topic.posts.with_deleted.order(created_at: :desc) : [@post]
+      @posts_to_delete.compact
diff --git a/assets/javascripts/discourse/initializers/hook-topic-controller.js.es6 b/assets/javascripts/discourse/initializers/hook-topic-controller.js.es6
index 0000000..6c6a6a4
--- /dev/null
+++ b/assets/javascripts/discourse/initializers/hook-topic-controller.js.es6
@@ -0,0 +1,139 @@
+import I18n from "I18n";
+import { withPluginApi } from "discourse/lib/plugin-api";
+import { ajax } from "discourse/lib/ajax";
+import Post from "discourse/models/post";
+export default {
+  name: "hook-topic-controller",
+  initialize() {
+    withPluginApi("0.8.32", (api) => {
+      api.modifyClass("controller:topic", {
+        permanentDeleteConfirmation(callback) {
+          bootbox.confirm(
+            I18n.t("encrypt.post.delete.confirm"),
+            I18n.t("encrypt.post.delete.no_value"),
+            I18n.t("encrypt.post.delete.yes_value"),
+            (result) => {
+              if (result) {
+                callback();
+              } else {
+                return;
+        createTimer(post_id) {
+          return ajax("/encrypt/encrypted_post_timers", {
+            type: "POST",
+            data: { post_id },
+        deleteTimer(post_id) {
+            type: "DELETE",
+        deleteTopic() {
+          // TODO: https://github.com/emberjs/ember.js/issues/15291
+          let { _super } = this;
+          if (this.model.encrypted_title) {
+            this.permanentDeleteConfirmation(() => {
+              return this.createTimer(
+                this.model.postStream.posts[0].id
+              ).then(() => this.model.destroy(this.currentUser));
+          } else {
+            return _super.call(this, ...arguments);
+        actions: {
+          deletePost(post) {
+            if (post.encrypted_raw && post.get("post_number") !== 1) {
+                return this.createTimer(post.id).then((result) => {
+                  post.setProperties({ delete_at: result.delete_at });
+            } else {
+          deleteSelected() {
+            const user = this.currentUser;
+            if (this.selectedAllPosts) {
+              this.send("toggleMultiSelect");
+              return this.deleteTopic();
+            if (this.selectedPosts[0].encrypted_raw) {
+                return this.createTimer(this.selectedPostIds).then((result) => {
+                  Post.deleteMany(this.selectedPostIds);
+                  this.get("model.postStream.posts").forEach((p) => {
+                    this.postSelected(p) &&
+                      p.setDeletedState(user) &&
+                      p.setProperties({
+                        delete_at: result.delete_at,
+                        deleted_at: new Date(),
+                        deleted_by: user,
+            } else {
+          recoverTopic() {
+              return this.deleteTimer(this.model.postStream.posts[0].id).then(
+                  this.model.postStream.posts[0].setProperties({
+                    delete_at: false,
+            } else {
+          recoverPost(post) {
+            if (post.encrypted_raw) {
+              return this.deleteTimer(post.id).then(() => {
+                post.setProperties({ delete_at: false });
+            } else {
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index 89345eb..edc05e4 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -32,6 +32,11 @@ en:
         checked: "This message will be end-to-end encrypted."
         unchecked: "Click the lock symbol to encrypt this message."
+      post:
+        delete:
GitHub sha: 3a1a2749
This commit appears in #79 which was approved by udan11. It was merged by lis2.
