FEATURE: Remove user topic timers and migrate to bookmarks with reminders (PR #10474)
GitHub
Wanted to double check whether this is the best place to do this, or in a post migrate? I figured I already have all the IDs here.
I can’t seem to find the dev topic regarding this but we should not use any ActiveRecord methods in migrations. Everything has to be done via raw SQL.
I think we can mark the topic_timers as executed so that we don’t have to reach into Sidekiq in a migration.
@tgxworld how do I still consistently forget this :sob: thanks for pointing that out.
@tgxworld well I do trash them…maybe I can just add a line to the job to say return if timer.trashed?. Probably better anyway so we don’t accidentally run any of these.
Yup something like that will probably work.
