FEATURE: Set custom document title separator (PR #9815)
This PR
  • Adds document_title_separator setting to update the title separator to enable different types of SEO titles, for example: Test Topic | Discourse. Defaults to " - ", as it was before.
  • Adds locale option for this new option
Note about tests
I’ve tried to write a meaningful test for this new option, but because the qunit creates it’s own titles I coudn’t verify in the test that this option applyis. qunit titles are separated with commas, for example: Test Topic,Qunit Discourse Test.
GitHub
hi, thanks. Can you tell why you think being able to customise this is important?
Sorry for the huge delay here. I am a bit mixed here.
@coding-horror is this a level of configurability you want admins to have? If not we are going to need to expose this as a plugin extension instead.
@zcuric recommend you open a topic on meta to discuss this.
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/seo-title-separator/155997/1
As per discussion on Discourse Meta, closing this PR.
