FEATURE: Show noscript view to unsupported browsers (PR #9373)
GitHub
This will detect IE11, but I think we should try to make this work for other old browsers as well.
Can we do if(!window.Promise) instead? Just like we check for window.WeakMap below.
We also need to check that this works with polyfills. If the IE11 polyfills are loaded, window.unsupportedBrowser should be false.
Won’t that mean we can’t ever use newer CSS ?
I mean for the next couple of months. I think we want to be able to merge this right now, then once we turn off the polyfills it will kick into action.
