FEATURE: SidekiqStats metrics (#194)
  • FEATURE: SidekiqStats metrics
  • SidekiqStats: new description for workers_size
  • Rewrite Sidekiq section of the README
diff --git a/README.md b/README.md
index a0bf9d6..05872c7 100644
--- a/README.md
+++ b/README.md
@@ -367,43 +367,49 @@ Metrics collected by Process instrumentation include labels `type` (as given wit
 #### Sidekiq metrics
-Including Sidekiq metrics (how many jobs ran? how many failed? how long did they take? how many are dead? how many were restarted?)
-`‍``ruby
-Sidekiq.configure_server do |config|
-   config.server_middleware do |chain|
-      require 'prometheus_exporter/instrumentation'
-      chain.add PrometheusExporter::Instrumentation::Sidekiq
-   end
-   config.death_handlers << PrometheusExporter::Instrumentation::Sidekiq.death_handler
-end
-To monitor Queue size and latency:
+There are different kinds of Sidekiq metrics that can be collected. A recommended setup looks like this:
 `‍``ruby
+  require 'prometheus_exporter/instrumentation'
+  config.server_middleware do |chain|
+    chain.add PrometheusExporter::Instrumentation::Sidekiq
+  end
+  config.death_handlers << PrometheusExporter::Instrumentation::Sidekiq.death_handler
   config.on :startup do
+    PrometheusExporter::Instrumentation::Process.start type: 'sidekiq'
+    PrometheusExporter::Instrumentation::SidekiqProcess.start
     PrometheusExporter::Instrumentation::SidekiqQueue.start
+    PrometheusExporter::Instrumentation::SidekiqStats.start
-This will only monitor the queues that are consumed by the sidekiq process you are on.  You can pass an `all_queues` parameter to monitor metrics on all queues.
+* The middleware and death handler will generate job specific metrics (how many jobs ran? how many failed? how long did they take? how many are dead? how many were restarted?).
+* The [`Process`](#per-process-stats) metrics provide basic ruby metrics.
+* The `SidekiqProcess` metrics provide the concurrency and busy metrics for this process.
+* The `SidekiqQueue` metrics provides size and latency for the queues run by this process.
+* The `SidekiqStats` metrics provide general, global Sidekiq stats (size of Scheduled, Retries, Dead queues, total number of jobs, etc).
+For `SidekiqQueue`, if you run more than one process for the same queues, note that the same metrics will be exposed by all the processes, just like the `SidekiqStats` will if you run more than one process of any kind. You might want use `avg` or `max` when consuming their metrics.
-To monitor Sidekiq process info:
+An alternative would be to expose these metrics in lone, long-lived process. Using a rake task, for example:
 `‍``ruby
-  config.on :startup do
-    PrometheusExporter::Instrumentation::Process.start type: 'sidekiq'
-    PrometheusExporter::Instrumentation::SidekiqProcess.start
-  end
+task :sidekiq_metrics do
+  server = PrometheusExporter::Server::WebServer.new
+  server.start
+  PrometheusExporter::Client.default = PrometheusExporter::LocalClient.new(collector: server.collector)
+  PrometheusExporter::Instrumentation::SidekiqQueue.start(all_queues: true)
+  sleep
+The `all_queues` parameter for `SidekiqQueue` will expose metrics for all queues.
 Sometimes the Sidekiq server shuts down before it can send metrics, that were generated right before the shutdown, to the collector. Especially if you care about the `sidekiq_restarted_jobs_total` metric, it is a good idea to explicitly stop the client:
 `‍``ruby
@@ -447,7 +453,21 @@ Both metrics will have a `queue` label with the name of the queue.
 | Gauge | `sidekiq_process_busy`        | Number of busy workers for this process |
 | Gauge | `sidekiq_process_concurrency` | Concurrency for this process            |
-Both metrics will include the labels `labels`, `queues`, `quiet`, `tag`, `hostname` and `identity`, as returned by the [Sidekiq API](https://github.com/mperham/sidekiq/wiki/API#processes).
+Both metrics will include the labels `labels`, `queues`, `quiet`, `tag`, `hostname` and `identity`, as returned by the [Sidekiq Processes API](https://github.com/mperham/sidekiq/wiki/API#processes).
+**PrometheusExporter::Instrumentation::SidekiqStats**
+| Type  | Name                            | Description                             |
+| Gauge | `sidekiq_stats_dead_size`       | Size of the dead queue                  |
+| Gauge | `sidekiq_stats_enqueued`        | Number of enqueued jobs                 |
+| Gauge | `sidekiq_stats_failed`          | Number of failed jobs                   |
+| Gauge | `sidekiq_stats_processed`       | Total number of processed jobs          |
+| Gauge | `sidekiq_stats_processes_size`  | Number of processes                     |
+| Gauge | `sidekiq_stats_retry_size`      | Size of the retries queue               |
+| Gauge | `sidekiq_stats_scheduled_size`  | Size of the scheduled queue             |
+| Gauge | `sidekiq_stats_workers_size`    | Number of jobs actively being processed |
+Based on the [Sidekiq Stats API](https://github.com/mperham/sidekiq/wiki/API#stats).
 _See [Metrics collected by Process Instrumentation](#metrics-collected-by-process-instrumentation) for a list of metrics the Process instrumentation will produce._
diff --git a/lib/prometheus_exporter/instrumentation.rb b/lib/prometheus_exporter/instrumentation.rb
index d3eb62c..1effe2d 100644
--- a/lib/prometheus_exporter/instrumentation.rb
+++ b/lib/prometheus_exporter/instrumentation.rb
@@ -6,6 +6,7 @@ require_relative "instrumentation/method_profiler"
 require_relative "instrumentation/sidekiq"
 require_relative "instrumentation/sidekiq_queue"
 require_relative "instrumentation/sidekiq_process"
+require_relative "instrumentation/sidekiq_stats"
 require_relative "instrumentation/delayed_job"
 require_relative "instrumentation/puma"
 require_relative "instrumentation/hutch"
diff --git a/lib/prometheus_exporter/instrumentation/sidekiq_stats.rb b/lib/prometheus_exporter/instrumentation/sidekiq_stats.rb
new file mode 100644
index 0000000..d4900ce
--- /dev/null
+++ b/lib/prometheus_exporter/instrumentation/sidekiq_stats.rb
@@ -0,0 +1,43 @@
+module PrometheusExporter::Instrumentation
+  class SidekiqStats
+    def self.start(client: nil, frequency: 30)
+      client ||= PrometheusExporter::Client.default
+      sidekiq_stats_collector = new
+      Thread.new do
+        loop do
+          begin
+            client.send_json(sidekiq_stats_collector.collect)
+          rescue StandardError => e
+            STDERR.puts("Prometheus Exporter Failed To Collect Sidekiq Stats metrics #{e}")
+          ensure
+            sleep frequency
+          end
+        end
+      end
+    end
+    def collect
+        type: 'sidekiq_stats',
+        stats: collect_stats
+    end
+    def collect_stats
+      stats = ::Sidekiq::Stats.new
+        'dead_size' => stats.dead_size,
+        'enqueued' => stats.enqueued,
+        'failed' => stats.failed,
+        'processed' => stats.processed,
+        'processes_size' => stats.processes_size,
+        'retry_size' => stats.retry_size,
+        'scheduled_size' => stats.scheduled_size,
+        'workers_size' => stats.workers_size,
+    end
+  end
+end
diff --git a/lib/prometheus_exporter/server.rb b/lib/prometheus_exporter/server.rb
index 423a7d7..cd3e40b 100644
--- a/lib/prometheus_exporter/server.rb
+++ b/lib/prometheus_exporter/server.rb
@@ -7,6 +7,7 @@ require_relative "server/process_collector"
 require_relative "server/sidekiq_collector"
 require_relative "server/sidekiq_queue_collector"
 require_relative "server/sidekiq_process_collector"
+require_relative "server/sidekiq_stats_collector"
 require_relative "server/delayed_job_collector"
GitHub sha: 854de20e2521048e79e07ff58b7b2efbfbbcf22e
This commit appears in #194 which was merged by SamSaffron.
