FEATURE: Skip small actions when counting replies in PMs. (#7108)
diff --git a/app/models/topic.rb b/app/models/topic.rb
index 419a063..028b6fc 100644
--- a/app/models/topic.rb
+++ b/app/models/topic.rb
@@ -527,10 +527,10 @@ class Topic < ActiveRecord::Base
   # Atomically creates the next post number
-  def self.next_post_number(topic_id, reply = false, whisper = false)
+  def self.next_post_number(topic_id, opts = {})
     highest = DB.query_single("SELECT coalesce(max(post_number),0) AS max FROM posts WHERE topic_id = ?", topic_id).first.to_i
-    if whisper
+    if opts[:whisper]
       result = DB.query_single(<<~SQL, highest, topic_id)
         UPDATE topics
@@ -543,13 +543,15 @@ class Topic < ActiveRecord::Base
     else
-      reply_sql = reply ? ", reply_count = reply_count + 1" : ""
+      reply_sql = opts[:reply] ? ", reply_count = reply_count + 1" : ""
+      posts_sql = opts[:post]  ? ", posts_count = posts_count + 1" : ""
       result = DB.query_single(<<~SQL, highest: highest, topic_id: topic_id)
         UPDATE topics
         SET highest_staff_post_number = :highest + 1,
-            highest_post_number = :highest + 1#{reply_sql},
-            posts_count = posts_count + 1
+            highest_post_number = :highest + 1
+            #{reply_sql}
+            #{posts_sql}
         WHERE id = :topic_id
         RETURNING highest_post_number
       SQL
@@ -585,6 +587,43 @@ class Topic < ActiveRecord::Base
         posts_count = Y.posts_count
       FROM X, Y
       WHERE
+        topics.archetype <> 'private_message' AND
+        X.topic_id = topics.id AND
+        Y.topic_id = topics.id AND (
+          topics.highest_staff_post_number <> X.highest_post_number OR
+          topics.highest_post_number <> Y.highest_post_number OR
+          topics.last_posted_at <> Y.last_posted_at OR
+          topics.posts_count <> Y.posts_count
+    SQL
+    DB.exec <<~SQL
+      WITH
+      X as (
+        SELECT topic_id,
+               COALESCE(MAX(post_number), 0) highest_post_number
+        FROM posts
+        WHERE deleted_at IS NULL
+        GROUP BY topic_id
+      Y as (
+        SELECT topic_id,
+               coalesce(MAX(post_number), 0) highest_post_number,
+               count(*) posts_count,
+               max(created_at) last_posted_at
+        FROM posts
+        WHERE deleted_at IS NULL AND post_type <> 3 AND post_type <> 4
+        GROUP BY topic_id
+      UPDATE topics
+      SET
+        highest_staff_post_number = X.highest_post_number,
+        highest_post_number = Y.highest_post_number,
+        last_posted_at = Y.last_posted_at,
+        posts_count = Y.posts_count
+      FROM X, Y
+      WHERE
+        topics.archetype = 'private_message' AND
@@ -597,32 +636,39 @@ class Topic < ActiveRecord::Base
   # If a post is deleted we have to update our highest post counters
   def self.reset_highest(topic_id)
+    archetype = Topic.where(id: topic_id).pluck(:archetype).first
+    # ignore small_action replies for private messages
+    post_type = archetype == Archetype.private_message ? " AND post_type <> #{Post.types[:small_action]}" : ''
     result = DB.query_single(<<~SQL, topic_id: topic_id)
       UPDATE topics
       SET
-      highest_staff_post_number = (
+        highest_staff_post_number = (
           SELECT COALESCE(MAX(post_number), 0) FROM posts
           WHERE topic_id = :topic_id AND
                 deleted_at IS NULL
-      highest_post_number = (
+        highest_post_number = (
                 post_type <> 4
+                #{post_type}
         posts_count = (
           SELECT count(*) FROM posts
                 post_type <> 4
+                #{post_type}
         last_posted_at = (
           SELECT MAX(created_at) FROM posts
                 post_type <> 4
+                #{post_type}
diff --git a/lib/post_creator.rb b/lib/post_creator.rb
index 6f77319..a74f43f 100644
--- a/lib/post_creator.rb
+++ b/lib/post_creator.rb
@@ -248,7 +248,11 @@ class PostCreator
     post.word_count = post.raw.scan(/[[:word:]]+/).size
     whisper = post.post_type == Post.types[:whisper]
-    post.post_number ||= Topic.next_post_number(post.topic_id, post.reply_to_post_number.present?, whisper)
+    increase_posts_count = !post.topic&.private_message? || post.post_type != Post.types[:small_action]
+    post.post_number ||= Topic.next_post_number(post.topic_id,
+      reply: post.reply_to_post_number.present?,
+      whisper: whisper,
+      post: increase_posts_count)
     cooking_options = post.cooking_options || {}
     cooking_options[:topic_id] = post.topic_id
diff --git a/spec/components/post_creator_spec.rb b/spec/components/post_creator_spec.rb
index 97a4960..2fe9345 100644
--- a/spec/components/post_creator_spec.rb
+++ b/spec/components/post_creator_spec.rb
@@ -776,6 +776,28 @@ describe PostCreator do
       expect(post.topic.topic_allowed_users.where(user_id: admin2.id).count).to eq(0)
+    it 'does not increase posts count for small actions' do
+      topic = Fabricate(:private_message_topic, user: Fabricate(:user))
+      Fabricate(:post, topic: topic)
+      1.upto(3) do |i|
+        user = Fabricate(:user)
+        topic.invite(topic.user, user.username)
+        topic.reload
+        expect(topic.posts_count).to eq(1)
+        expect(topic.posts.where(post_type: Post.types[:small_action]).count).to eq(i)
+      end
+      Topic.reset_highest(topic.id)
+      expect(topic.reload.posts_count).to eq(2)
+      Topic.reset_all_highest!
+      expect(topic.reload.posts_count).to eq(3)
+    end
   context "warnings" do
GitHub sha: 2312cacc
