FEATURE: the ability to search users by custom fields (PR #12762)
When the admin creates a new custom field they can specify if that field should be searchable or not.
That setting is taken into consideration for quick search results.
GitHub
I recommend every boolean should be null: false since it just causes problems and is basically the same as false.
This is adding a fair amount of work to every search - at least one extra query plus a join.
Suggestion: Add the custom field to the user_search_data via SearchIndexer, then you get this free?
Is there any simple way to show the custom field as well, when you have a user hit? That way it would say city: Sydney and the user will be a lot less confused about why this pops up.
One trick you can use here to avoid this endless list of tracked properties:
@computed("userField.{editable,required,show_on_profile,show_on_user_card,searchable"}
flags(userField) {
  // userField.required ...
can you wrap the I18n in a span please?
