FEATURE: tighter limits on per cluster post rebakes
We have the periodical job that regularly will rebake old posts. This is used to trickle in update to cooked markdown. The problem is that each rebake can issue multiple background jobs (post process and pull hotlinked images)
Previously we had no per-cluster limit so cluster running 100s of sites could flood the sidekiq queue with rebake related jobs.
New system introduces a hard limit of 300 rebakes per 15 minutes across a cluster to ensure the sidekiq job is not dominated by this.
We also reduced rebake_old_posts_count to 80, which is a safer default.
diff --git a/app/models/post.rb b/app/models/post.rb
index 7279a0f..ff6c328 100644
--- a/app/models/post.rb
+++ b/app/models/post.rb
@@ -516,13 +516,32 @@ class Post < ActiveRecord::Base
   def self.rebake_old(limit)
+    limiter = RateLimiter.new(
+      nil,
+      "global_periodical_rebake_limit",
+      GlobalSetting.max_old_rebakes_per_15_minutes,
+      900,
+      global: true
     problems = []
     Post.where('baked_version IS NULL OR baked_version < ?', BAKED_VERSION)
       .order('id desc')
       .limit(limit).pluck(:id).each do |id|
       begin
+        break if !limiter.can_perform?
         post = Post.find(id)
         post.rebake!
+        begin
+          limiter.performed!
+        rescue RateLimiter::LimitExceeded
+          break
+        end
       rescue => e
         problems << { post: post, ex: e }
diff --git a/config/discourse_defaults.conf b/config/discourse_defaults.conf
index 43ce40b..cde2c36 100644
--- a/config/discourse_defaults.conf
+++ b/config/discourse_defaults.conf
@@ -202,3 +202,8 @@ force_anonymous_min_queue_seconds = 1
 # only trigger anon if we see more than N requests for this path in last 10 seconds
 force_anonymous_min_per_10_seconds = 3
+# maximum number of posts rebaked across the cluster in the periodical job
+# rebake process is very expensive, on multisite we have to make sure we never
+# flood the queue
+max_old_rebakes_per_15_minutes = 300
diff --git a/config/site_settings.yml b/config/site_settings.yml
index ebfd493..afaa044 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1411,7 +1411,7 @@ developer:
   top_topics_formula_least_likes_per_post_multiplier:
     default: 3
   rebake_old_posts_count:
-    default: 100
+    default: 80
     min: 1
   migrate_to_new_scheme:
     hidden: true
diff --git a/spec/models/post_spec.rb b/spec/models/post_spec.rb
index dce8391..9ddfccf 100644
--- a/spec/models/post_spec.rb
+++ b/spec/models/post_spec.rb
@@ -1153,6 +1153,27 @@ describe Post do
       post.reload
       expect(post.baked_at).to eq(baked)
+    it "will rate limit globally" do
+      post1 = create_post
+      post2 = create_post
+      post3 = create_post
+      Post.where(id: [post1.id, post2.id, post3.id]).update_all(baked_version: -1)
+      global_setting :max_old_rebakes_per_15_minutes, 2
+      RateLimiter.clear_all_global!
+      RateLimiter.enable
+      Post.rebake_old(100)
+      expect(post3.reload.baked_version).not_to eq(-1)
+      expect(post2.reload.baked_version).not_to eq(-1)
+      expect(post1.reload.baked_version).to eq(-1)
+    end
   describe ".unhide!" do
GitHub sha: 70269c7c
Revert "Revert "FEATURE: force rebake of all posts with images""
