FEATURE: treat theme_uploads as settings in JavaScript
This change allows themes and components access to theme assets.
This means that inside theme js you can now get the URL for an asset with:
settings.theme_uploads.name
diff --git a/app/models/theme.rb b/app/models/theme.rb
index d5d8554..a307d3a 100644
--- a/app/models/theme.rb
+++ b/app/models/theme.rb
@@ -430,6 +430,16 @@ class Theme < ActiveRecord::Base
       self.settings.each do |setting|
         hash[setting.name] = setting.value
+      theme_uploads = {}
+      theme_fields
+        .joins(:upload)
+        .where(type_id: ThemeField.types[:theme_upload_var]).each do |field|
+        theme_uploads[field.name] = field.upload.url
+      end
+      hash['theme_uploads'] = theme_uploads if theme_uploads.present?
       hash
diff --git a/lib/stylesheet/importer.rb b/lib/stylesheet/importer.rb
index 7258a99..d06b4db 100644
--- a/lib/stylesheet/importer.rb
+++ b/lib/stylesheet/importer.rb
@@ -63,6 +63,7 @@ module Stylesheet
       theme&.included_settings&.each do |name, value|
+        next if name == "theme_uploads"
         contents << to_scss_variable(name, value)
diff --git a/spec/models/theme_spec.rb b/spec/models/theme_spec.rb
index d760a5f..fb47cfb 100644
--- a/spec/models/theme_spec.rb
+++ b/spec/models/theme_spec.rb
@@ -546,6 +546,18 @@ HTML
     expect(messages.first.data.map { |d| d[:target] }).to contain_exactly(:admin, :desktop, :desktop_theme, :mobile, :mobile_theme)
+  it 'includes theme_uploads in settings' do
+    Theme.destroy_all
+    upload = Fabricate(:upload)
+    theme.set_field(type: :theme_upload_var, target: :common, name: "bob", upload_id: upload.id)
+    theme.save!
+    json = JSON.parse(cached_settings(theme.id))
+    expect(json["theme_uploads"]["bob"]).to eq(upload.url)
+  end
   it 'handles settings cache correctly' do
     Theme.destroy_all
GitHub sha: 719a93c3
