FEATURE: Use path from existing URL of uploads and optimized images (#13177)
Discourse shouldn’t dynamically calculate the path of uploads and optimized images after a file has been stored on disk or S3. Otherwise it might calculate the wrong path if the SHA1 or extension stored in the database doesn’t match the actual file path.
diff --git a/lib/file_store/base_store.rb b/lib/file_store/base_store.rb
index 44749f5..80f1fb6 100644
--- a/lib/file_store/base_store.rb
+++ b/lib/file_store/base_store.rb
@@ -3,13 +3,17 @@
 module FileStore
   class BaseStore
+    UPLOAD_PATH_REGEX = %r|/(original/\d+X/.*)|
+    OPTIMIZED_IMAGE_PATH_REGEX = %r|/(optimized/\d+X/.*)|
     def store_upload(file, upload, content_type = nil)
+      upload.url = nil
       path = get_path_for_upload(upload)
       store_file(file, path)
     def store_optimized_image(file, optimized_image, content_type = nil, secure: false)
+      optimized_image.url = nil
       path = get_path_for_optimized_image(optimized_image)
@@ -116,6 +120,12 @@ module FileStore
     def get_path_for_upload(upload)
+      # try to extract the path from the URL instead of calculating it,
+      # because the calculated path might differ from the actual path
+      if upload.url.present? && (path = upload.url[UPLOAD_PATH_REGEX, 1])
+        return prefix_path(path)
+      end
       extension =
         if upload.extension
           ".#{upload.extension}"
@@ -128,6 +138,12 @@ module FileStore
     def get_path_for_optimized_image(optimized_image)
+      if optimized_image.url.present? && (path = optimized_image.url[OPTIMIZED_IMAGE_PATH_REGEX, 1])
+      end
       upload = optimized_image.upload
       version = optimized_image.version || 1
       extension = "_#{version}_#{optimized_image.width}x#{optimized_image.height}#{optimized_image.extension}"
@@ -178,6 +194,9 @@ module FileStore
       depths.max
+    def prefix_path(path)
+      path
+    end
diff --git a/lib/file_store/local_store.rb b/lib/file_store/local_store.rb
index 2564953..e945ac1 100644
--- a/lib/file_store/local_store.rb
+++ b/lib/file_store/local_store.rb
@@ -66,7 +66,7 @@ module FileStore
     def get_path_for(type, upload_id, sha, extension)
-      File.join("/", upload_path, super(type, upload_id, sha, extension))
+      prefix_path(super(type, upload_id, sha, extension))
     def copy_file(file, path)
@@ -134,5 +134,8 @@ module FileStore
       puts "#{count} of #{model.count} #{model.name.underscore.pluralize} are missing" if count > 0
+      File.join("/", upload_path, path)
+    end
diff --git a/lib/file_store/s3_store.rb b/lib/file_store/s3_store.rb
index ab6e56b..c0671ca 100644
--- a/lib/file_store/s3_store.rb
+++ b/lib/file_store/s3_store.rb
@@ -22,6 +22,7 @@ module FileStore
+      upload.url = nil
       url, upload.etag = store_file(
         file,
@@ -35,6 +36,7 @@ module FileStore
       url, optimized_image.etag = store_file(file, path, content_type: content_type, private_acl: secure)
       url
diff --git a/lib/shrink_uploaded_image.rb b/lib/shrink_uploaded_image.rb
index 43416ad..fbcdfd6 100644
--- a/lib/shrink_uploaded_image.rb
+++ b/lib/shrink_uploaded_image.rb
@@ -67,7 +67,7 @@ class ShrinkUploadedImage
     log "base62: #{original_upload.base62_sha1} -> #{Upload.base62_sha1(sha1)}"
     log "sha: #{original_upload.sha1} -> #{sha1}"
-    log "(an exisiting upload)" if existing_upload
+    log "(an existing upload)" if existing_upload
     success = true
     posts = Post.unscoped.joins(:post_uploads).where(post_uploads: { upload_id: original_upload.id }).uniq.sort_by(&:created_at)
diff --git a/spec/components/email/sender_spec.rb b/spec/components/email/sender_spec.rb
index 3f80e23..bacf426 100644
--- a/spec/components/email/sender_spec.rb
+++ b/spec/components/email/sender_spec.rb
@@ -489,8 +489,8 @@ describe Email::Sender do
           let!(:optimized_image_file) { file_from_fixtures("smallest.png", "images") }
           before do
-            Discourse.store.store_optimized_image(optimized_image_file, optimized)
-            optimized.update(url: Discourse.store.absolute_base_url + '/' + optimized.url)
+            url = Discourse.store.store_optimized_image(optimized_image_file, optimized)
+            optimized.update(url: Discourse.store.absolute_base_url + '/' + url)
             Discourse.store.cache_file(optimized_image_file, File.basename("#{optimized.sha1}.png"))
diff --git a/spec/components/file_store/base_store_spec.rb b/spec/components/file_store/base_store_spec.rb
index 4771b28..05befda 100644
--- a/spec/components/file_store/base_store_spec.rb
+++ b/spec/components/file_store/base_store_spec.rb
@@ -6,42 +6,136 @@ RSpec.describe FileStore::BaseStore do
   fab!(:upload) { Fabricate(:upload, id: 9999, sha1: Digest::SHA1.hexdigest('9999')) }
   describe '#get_path_for_upload' do
-    it 'should return the right path' do
-      expect(FileStore::BaseStore.new.get_path_for_upload(upload))
-        .to eq('original/2X/4/4170ac2a2782a1516fe9e13d7322ae482c1bd594.png')
+    def expect_correct_path(expected_path)
+      expect(described_class.new.get_path_for_upload(upload)).to eq(expected_path)
-    describe 'when Upload#extension has not been set' do
+    context "empty URL" do
+      before do
+        upload.update!(url: "")
+      end
-        upload.update!(extension: nil)
+        expect_correct_path('original/2X/4/4170ac2a2782a1516fe9e13d7322ae482c1bd594.png')
+      end
+      describe 'when Upload#extension has not been set' do
+        it 'should return the right path' do
+          upload.update!(extension: nil)
+        end
+      end
+      describe 'when id is negative' do
+        it 'should return the right depth' do
+          upload.update!(id: -999)
+          expect_correct_path('original/1X/4170ac2a2782a1516fe9e13d7322ae482c1bd594.png')
+        end
-    describe 'when id is negative' do
-      it 'should return the right depth' do
-        upload.update!(id: -999)
+    context "existing URL" do
+      context "regular site" do
+        it "returns the correct path for files stored on local storage" do
+          upload.update!(url: "/uploads/default/original/1X/63b76551662ccea1a594e161c37dd35188d77657.jpeg")
+          expect_correct_path("original/1X/63b76551662ccea1a594e161c37dd35188d77657.jpeg")
+          upload.update!(url: "/uploads/default/original/3X/63/63b76551662ccea1a594e161c37dd35188d77657.jpeg")
+          expect_correct_path("original/3X/63/63b76551662ccea1a594e161c37dd35188d77657.jpeg")
+        end
+        it "returns the correct path for files stored on S3" do
+          upload.update!(url: "//bucket-name.s3.dualstack.us-west-2.amazonaws.com/original/1X/63b76551662ccea1a594e161c37dd35188d77657.jpeg")
+          upload.update!(url: "//bucket-name.s3.dualstack.us-west-2.amazonaws.com/original/3X/63/63b76551662ccea1a594e161c37dd35188d77657.jpeg")
+        end
+      end
+      context "multisite" do
+          upload.update!(url: "/uploads/foo/original/1X/63b76551662ccea1a594e161c37dd35188d77657.jpeg")
GitHub sha: 157f10db
This commit appears in #13177 which was approved by eviltrout. It was merged by gschlager.
