FEATURE: Use the site's small logo as the system user's avatar. (#11661)
FEATURE: Use the site’s small logo as the system user’s avatar. (#11661)
diff --git a/app/models/user.rb b/app/models/user.rb
index 6b26110..305b7b5 100644
--- a/app/models/user.rb
+++ b/app/models/user.rb
@@ -868,7 +868,11 @@ class User < ActiveRecord::Base
   def avatar_template
-    self.class.avatar_template(username, uploaded_avatar_id)
+    if id == Discourse::SYSTEM_USER_ID && SiteSetting.logo_small
+      UrlHelper.absolute(SiteSetting.logo_small.url)
+    else
+      self.class.avatar_template(username, uploaded_avatar_id)
+    end
   # The following count methods are somewhat slow - definitely don't use them in a loop.
diff --git a/spec/models/user_spec.rb b/spec/models/user_spec.rb
index 3a7a609..33bd7b5 100644
--- a/spec/models/user_spec.rb
+++ b/spec/models/user_spec.rb
@@ -1337,6 +1337,29 @@ describe User do
+  describe '#avatar_template' do
+    it 'uses the small logo if the user is the system user' do
+      logo_small_url = UrlHelper.absolute(SiteSetting.logo_small.url)
+      expect(Discourse.system_user.avatar_template).to eq(logo_small_url)
+    end
+    it 'uses the system user avatar if the logo is nil' do
+      SiteSetting.logo_small = nil
+      system_user = Discourse.system_user
+      expected = User.avatar_template(system_user.username, system_user.uploaded_avatar_id)
+      expect(Discourse.system_user.avatar_template).to eq(expected)
+    end
+    it 'uses the regular avatar for other users' do
+      user = Fabricate(:user)
+      expected = User.avatar_template(user.username, user.uploaded_avatar_id)
+      expect(user.avatar_template).to eq(expected)
+    end
+  end
   describe "update_posts_read!" do
     context "with a UserVisit record" do
       let!(:user) { Fabricate(:user) }
GitHub sha: caa17386
This commit appears in #11661 which was approved by eviltrout. It was merged by romanrizzi.
