FIX: Account for nil when looking up subcategories
diff --git a/app/models/concerns/category_hashtag.rb b/app/models/concerns/category_hashtag.rb
index 8e61329b93..5a8c92f92c 100644
--- a/app/models/concerns/category_hashtag.rb
+++ b/app/models/concerns/category_hashtag.rb
@@ -12,7 +12,7 @@ module CategoryHashtag
       category = Category.where(slug: parent_slug, parent_category_id: nil)
       if child_slug
-        Category.where(slug: child_slug, parent_category_id: category.pluck(:id).first).first
+        Category.where(slug: child_slug, parent_category_id: category.select(:id)).first
       else
         category.first
diff --git a/spec/components/concern/category_hashtag_spec.rb b/spec/components/concern/category_hashtag_spec.rb
index e446fc27d2..3d59995bab 100644
--- a/spec/components/concern/category_hashtag_spec.rb
+++ b/spec/components/concern/category_hashtag_spec.rb
@@ -25,6 +25,10 @@ describe CategoryHashtag do
       expect(Category.query_from_hashtag_slug("random-slug#{CategoryHashtag::SEPARATOR}random-slug")).to eq(nil)
+    it "should return nil for a non-existent root and a parent subcategory" do
+      expect(Category.query_from_hashtag_slug("non-existent#{CategoryHashtag::SEPARATOR}#{parent_category.slug}")).to eq(nil)
+    end
     it "should be case sensitive" do
       parent_category.update!(slug: "ApPlE")
       child_category.update!(slug: "OraNGE")
GitHub sha: 7a0c0669
