FIX: Add additional checks for automatic theme script CSP
  • Skip absolute URLs
  • Skip CDN URLs
  • Skip invalid URLs
  • Properly format protocol-less URLs
diff --git a/lib/content_security_policy/extension.rb b/lib/content_security_policy/extension.rb
index f7b49b2..4c8231b 100644
--- a/lib/content_security_policy/extension.rb
+++ b/lib/content_security_policy/extension.rb
@@ -62,7 +62,18 @@ class ContentSecurityPolicy
       html_fields.each(&:ensure_baked!)
       doc = html_fields.map(&:value_baked).join("\n")
       Nokogiri::HTML.fragment(doc).css('script[src]').each do |node|
-        auto_script_src_extension[:script_src] << node['src']
+        src = node['src']
+        uri = URI(src)
+        next if GlobalSetting.cdn_url && src.starts_with?(GlobalSetting.cdn_url) # Ignore CDN urls (theme-javascripts)
+        next if uri.host.nil? # Ignore same-domain scripts (theme-javascripts)
+        next if uri.path.nil? # Ignore raw hosts
+        uri_string = uri.to_s.sub(/^\/\//, '') # Protocol-less CSP should not have // at beginning of URL
+        auto_script_src_extension[:script_src] << uri_string
+      rescue URI::Error
+        # Ignore invalid URI
       extensions << auto_script_src_extension
diff --git a/spec/lib/content_security_policy_spec.rb b/spec/lib/content_security_policy_spec.rb
index d9eb978..168887c 100644
--- a/spec/lib/content_security_policy_spec.rb
+++ b/spec/lib/content_security_policy_spec.rb
@@ -216,10 +216,20 @@ describe ContentSecurityPolicy do
     it 'is extended automatically when themes reference external scripts' do
       policy # call this first to make sure further actions clear the cache
-      theme.set_field(target: :common, name: "header", value: "<script src='https://example.com/myscript.js'/>")
+      theme.set_field(target: :common, name: "header", value: <<~SCRIPT)
+        <script src='https://example.com/myscript.js'/>
+        <script src='//example2.com/protocol-less-script.js'/>
+        <script src='domain-only.com'/>
+        <script>console.log('inline script')</script>
+      SCRIPT
+      theme.set_field(target: :desktop, name: "header", value: "")
       theme.save!
       expect(parse(theme_policy)['script-src']).to include('https://example.com/myscript.js')
+      expect(parse(theme_policy)['script-src']).to include('example2.com/protocol-less-script.js')
+      expect(parse(theme_policy)['script-src']).not_to include('domain-only.com')
+      expect(parse(theme_policy)['script-src']).not_to include(a_string_matching /^\/theme-javascripts/)
       theme.destroy!
GitHub sha: f95609ae
https://meta.discourse.org/t/csp-error-couldnt-parse-invalid-host-theme-javascripts/149255/4
https://meta.discourse.org/t/automatically-adding-theme-scripts-to-csp/149028/4
