FIX: Add `getURL` back in
FIX: Add getURL back in
I think the failure was unrelated
diff --git a/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6 b/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
index 9f2f67e..45836be 100644
--- a/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
+++ b/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
@@ -6,6 +6,7 @@ import { h } from "virtual-dom";
 import { queryRegistry } from "discourse/widgets/widget";
 import { getOwner } from "discourse-common/lib/get-owner";
 import { htmlSafe } from "@ember/template";
+import getURL from "discourse-common/lib/get-url";
 function titleForState(user) {
   if (user) {
@@ -102,7 +103,7 @@ function initialize(api) {
     customHref: category => {
       if (category) {
         return (
-          Discourse.getURL(category.url) +
+          getURL(category.url) +
           "/l/latest?status=open&assigned=nobody"
@@ -173,7 +174,7 @@ function initialize(api) {
     @computed("assigned_to_user")
     assignedToUserPath(assignedToUser) {
       const siteSettings = api.container.lookup("site-settings:main");
-      return Discourse.getURL(
+      return getURL(
         siteSettings.assigns_user_url_path.replace(
           "{username}",
           assignedToUser.username
@@ -185,7 +186,7 @@ function initialize(api) {
   api.modifyClass("model:bookmark", {
+      return getURL(
         this.siteSettings.assigns_user_url_path.replace(
           "{username}",
GitHub sha: a9916849
