FIX: Add suppress_anonymous_pageviews site setting (PR #12800)
For example, for sites with login_required set to true, counting anonymous pageviews is confusing.
GitHub
Can we name the setting simply suppress_anonymous_pageviews? Actually, suppress sounds like the pageviews are deleted, maybe ignore_anonymous_pageviews is clearer?
This will exclude anonymous views for login required sites regardless of the setting, right? (Or I am reading this wrong? I have trouble parsing “not this OR not that” in my head.
I think it would be good to have a test case with login_required = true and suppress_anonymous_pageviews_on_private_sites = false.
:+1:
Double negations is super hard :exploding_head:
Looks like it.
Yes, exactly. At first I wanted to call it just suppress_anonymous_pageviews, but I wanted to point out the site has to be private (login_required = true).
It’s fine we can include that in the description of the setting :wink:
Hmm… it’s a hidden setting though.
That’s a very good point. Still I much prefer the shorter name. If they want to change it, they will need to do it via the console/ENV, so they will have to understand what it does
no need for a try here, once it exists in discourse_defaults it is safe to use.
That said, I say we just kill the setting altogether, it is not named right.
ignore_anon_views_on_private_sites is probably more correct, but it a mouthful.
Let’s offer no setting, then if someone complains they need a setting we can consider adding it.
Good to merge once my comment is addressed! :+1:
