FIX: add table CSS rules to normalize (#10176)
  • FIX: add table CSS rules to normalize
In the new version of normalize - 8.0.1 tableandtd` CSS rules are missing https://github.com/necolas/normalize.css/blob/master/normalize.css
They existed in version 3.0.1 https://github.com/necolas/normalize.css/blob/3.0.1/normalize.css#L417
Also, extracted custom rules to new file
diff --git a/app/assets/stylesheets/common.scss b/app/assets/stylesheets/common.scss
index 2165d73..bdf45f0 100644
--- a/app/assets/stylesheets/common.scss
+++ b/app/assets/stylesheets/common.scss
@@ -1,4 +1,5 @@
 @import "vendor/normalize";
+@import "vendor/normalize-ext";
 @import "vendor/pikaday";
 @import "common/foundation/helpers";
 @import "common/foundation/base";
diff --git a/app/assets/stylesheets/embed.scss b/app/assets/stylesheets/embed.scss
index d0acdb1..0e70d09 100644
--- a/app/assets/stylesheets/embed.scss
+++ b/app/assets/stylesheets/embed.scss
@@ -1,4 +1,5 @@
 @import "./vendor/normalize";
+@import "./vendor/normalize-ext";
 @import "./common/foundation/base";
 @import "./common/foundation/variables";
 @import "./common/foundation/colors";
diff --git a/app/assets/stylesheets/vendor/normalize-ext.scss b/app/assets/stylesheets/vendor/normalize-ext.scss
new file mode 100644
index 0000000..1dff166
--- /dev/null
+++ b/app/assets/stylesheets/vendor/normalize-ext.scss
@@ -0,0 +1,20 @@
+/* Discourse custom changes for backward compatiblity
+button,
+input,
+optgroup,
+select,
+textarea {
+  color: inherit;
+table {
+  border-collapse: collapse;
+  border-spacing: 0;
+td,
+th {
+  padding: 0;
diff --git a/app/assets/stylesheets/vendor/normalize.scss b/app/assets/stylesheets/vendor/normalize.scss
index 6980a9b..192eb9c 100644
--- a/app/assets/stylesheets/vendor/normalize.scss
+++ b/app/assets/stylesheets/vendor/normalize.scss
@@ -347,362 +347,3 @@ template {
 [hidden] {
   display: none;
-  * Discourse backward compatibility
-/*! normalize.css v8.0.1 | MIT License | github.com/necolas/normalize.css */
-/* Document
- * 1. Correct the line height in all browsers.
- * 2. Prevent adjustments of font size after orientation changes in iOS.
-html {
-  line-height: 1.15; /* 1 */
-  -webkit-text-size-adjust: 100%; /* 2 */
-/* Sections
- * Remove the margin in all browsers.
-body {
-  margin: 0;
- * Render the `main` element consistently in IE.
-main {
-  display: block;
- * Correct the font size and margin on `h1` elements within `section` and
- * `article` contexts in Chrome, Firefox, and Safari.
-h1 {
-  font-size: 2em;
-  margin: 0.67em 0;
-/* Grouping content
- * 1. Add the correct box sizing in Firefox.
- * 2. Show the overflow in Edge and IE.
-hr {
-  box-sizing: content-box; /* 1 */
-  height: 0; /* 1 */
-  overflow: visible; /* 2 */
- * 1. Correct the inheritance and scaling of font size in all browsers.
- * 2. Correct the odd `em` font sizing in all browsers.
-pre {
-  font-family: monospace, monospace; /* 1 */
-  font-size: 1em; /* 2 */
-/* Text-level semantics
- * Remove the gray background on active links in IE 10.
-a {
-  background-color: transparent;
- * 1. Remove the bottom border in Chrome 57-
- * 2. Add the correct text decoration in Chrome, Edge, IE, Opera, and Safari.
-abbr[title] {
-  border-bottom: none; /* 1 */
-  text-decoration: underline; /* 2 */
-  text-decoration: underline dotted; /* 2 */
- * Add the correct font weight in Chrome, Edge, and Safari.
-b,
-strong {
-  font-weight: bolder;
-code,
-kbd,
-samp {
- * Add the correct font size in all browsers.
-small {
-  font-size: 80%;
- * Prevent `sub` and `sup` elements from affecting the line height in
- * all browsers.
-sub,
-sup {
-  font-size: 75%;
-  line-height: 0;
-  position: relative;
-  vertical-align: baseline;
-sub {
-  bottom: -0.25em;
-sup {
-  top: -0.5em;
-/* Embedded content
- * Remove the border on images inside links in IE 10.
-img {
-  border-style: none;
-/* Forms
- * 1. Change the font styles in all browsers.
- * 2. Remove the margin in Firefox and Safari.
-button,
-input,
-optgroup,
-select,
-textarea {
-  font-family: inherit; /* 1 */
-  font-size: 100%; /* 1 */
-  margin: 0; /* 2 */
- * Show the overflow in IE.
- * 1. Show the overflow in Edge.
-button,
-input { /* 1 */
- * Remove the inheritance of text transform in Edge, Firefox, and IE.
- * 1. Remove the inheritance of text transform in Firefox.
-button,
-select { /* 1 */
-  text-transform: none;
- * Correct the inability to style clickable types in iOS and Safari.
-button,
-[type="button"],
-[type="reset"],
-[type="submit"] {
-  -webkit-appearance: button;
- * Remove the inner border and padding in Firefox.
-button::-moz-focus-inner,
-[type="button"]::-moz-focus-inner,
-[type="reset"]::-moz-focus-inner,
-[type="submit"]::-moz-focus-inner {
-  padding: 0;
- * Restore the focus styles unset by the previous rule.
-button:-moz-focusring,
-[type="button"]:-moz-focusring,
-[type="reset"]:-moz-focusring,
-[type="submit"]:-moz-focusring {
-  outline: 1px dotted ButtonText;
- * Correct the padding in Firefox.
-fieldset {
-  padding: 0.35em 0.75em 0.625em;
- * 1. Correct the text wrapping in Edge and IE.
- * 2. Correct the color inheritance from `fieldset` elements in IE.
- * 3. Remove the padding so developers are not caught out when they zero out
- *    `fieldset` elements in all browsers.
-legend {
-  box-sizing: border-box; /* 1 */
-  color: inherit; /* 2 */
-  display: table; /* 1 */
-  max-width: 100%; /* 1 */
-  padding: 0; /* 3 */
-  white-space: normal; /* 1 */
- * Add the correct vertical alignment in Chrome, Firefox, and Opera.
-progress {
- * Remove the default vertical scrollbar in IE 10+.
-textarea {
-  overflow: auto;
- * 1. Add the correct box sizing in IE 10.
- * 2. Remove the padding in IE 10.
-[type="checkbox"],
-[type="radio"] {
-  padding: 0; /* 2 */
- * Correct the cursor style of increment and decrement buttons in Chrome.
-[type="number"]::-webkit-inner-spin-button,
-[type="number"]::-webkit-outer-spin-button {
-  height: auto;
- * 1. Correct the odd appearance in Chrome and Safari.
- * 2. Correct the outline style in Safari.
-[type="search"] {
-  -webkit-appearance: textfield; /* 1 */
-  outline-offset: -2px; /* 2 */
- * Remove the inner padding in Chrome and Safari on macOS.
-[type="search"]::-webkit-search-decoration {
-  -webkit-appearance: none;
- * 1. Correct the inability to style clickable types in iOS and Safari.
- * 2. Change font properties to `inherit` in Safari.
-::-webkit-file-upload-button {
-  -webkit-appearance: button; /* 1 */
-  font: inherit; /* 2 */
-/* Interactive
- * Add the correct display in Edge, IE 10+, and Firefox.
-details {
-  display: block;
- * Add the correct display in all browsers.
-summary {
-  display: list-item;
-/* Misc
GitHub sha: 72861f4e
