FIX: add_to_serializer not correctly accounting for inheritance chains
This is a very long standing bug we had, if a plugin attempted to amend a serializer core was not “correcting” the situation for all descendant classes this often only showed up in production cause production eager loads serializers prior to plugins amending them.
This is a critical fix for various plugins
diff --git a/lib/plugin/instance.rb b/lib/plugin/instance.rb
index 3c45aa7..94037ff 100644
--- a/lib/plugin/instance.rb
+++ b/lib/plugin/instance.rb
@@ -94,18 +94,21 @@ class Plugin::Instance
   def add_to_serializer(serializer, attr, define_include_method = true, &block)
     reloadable_patch do |plugin|
-      klass = "#{serializer.to_s.classify}Serializer".constantize rescue "#{serializer.to_s}Serializer".constantize
+      base = "#{serializer.to_s.classify}Serializer".constantize rescue "#{serializer.to_s}Serializer".constantize
-      unless attr.to_s.start_with?("include_")
-        klass.attributes(attr)
+      # we have to work through descendants cause serializers may already be baked and cached
+      ([base] + base.descendants).each do |klass|
+        unless attr.to_s.start_with?("include_")
+          klass.attributes(attr)
-        if define_include_method
-          # Don't include serialized methods if the plugin is disabled
-          klass.public_send(:define_method, "include_#{attr}?") { plugin.enabled? }
+          if define_include_method
+            # Don't include serialized methods if the plugin is disabled
+            klass.public_send(:define_method, "include_#{attr}?") { plugin.enabled? }
+          end
-      end
-      klass.public_send(:define_method, attr, &block)
+        klass.public_send(:define_method, attr, &block)
+      end
diff --git a/spec/components/plugin/instance_spec.rb b/spec/components/plugin/instance_spec.rb
index 916fef5..76ecc02 100644
--- a/spec/components/plugin/instance_spec.rb
+++ b/spec/components/plugin/instance_spec.rb
@@ -34,7 +34,25 @@ describe Plugin::Instance do
     context "with a plugin that extends things" do
       class Trout; end
-      class TroutSerializer < ApplicationSerializer; end
+      class TroutSerializer < ApplicationSerializer
+        attribute :name
+        def name
+          "a trout"
+        end
+      end
+      class TroutJuniorSerializer < TroutSerializer
+        attribute :i_am_child
+        def name
+          "a trout jr"
+        end
+        def i_am_child
+          true
+        end
+      end
       class TroutPlugin < Plugin::Instance
         attr_accessor :enabled
@@ -47,6 +65,12 @@ describe Plugin::Instance do
         @plugin = TroutPlugin.new
         @trout = Trout.new
+        poison = TroutSerializer.new(@trout)
+        poison.attributes
+        poison = TroutJuniorSerializer.new(@trout)
+        poison.attributes
         # New method
         @plugin.add_to_class(:trout, :status?) { "evil" }
@@ -57,7 +81,9 @@ describe Plugin::Instance do
         # Serializer
         @plugin.add_to_serializer(:trout, :scales) { 1024 }
         @serializer = TroutSerializer.new(@trout)
+        @child_serializer = TroutJuniorSerializer.new(@trout)
       after do
@@ -74,6 +100,8 @@ describe Plugin::Instance do
         expect(@serializer.scales).to eq(1024)
         expect(@serializer.include_scales?).to eq(true)
+        expect(@child_serializer.attributes[:scales]).to eq(1024)
         # When a plugin is disabled
         @plugin.enabled = false
         expect(@trout.status?).to eq(nil)
@@ -81,7 +109,11 @@ describe Plugin::Instance do
         expect(@hello_count).to eq(1)
         expect(@serializer.include_scales?).to eq(false)
+        expect(@serializer.name).to eq("a trout")
+        expect(@child_serializer.scales).to eq(1024)
+        expect(@child_serializer.include_scales?).to eq(false)
+        expect(@child_serializer.name).to eq("a trout jr")
GitHub sha: bd5fa173
FIX: keep plugin compatible with older discourse versions
Didn’t know Trouts were poisonous? :wink:
