FIX: Adds important declaration to `.hidden` utility/helper class
FIX: Adds important declaration to .hidden utility/helper class
This commit adds the !important declaration to .hidden utility/helper class. Without the !important declaration, it is not applied correctly across the site.
diff --git a/app/assets/stylesheets/common/foundation/helpers.scss b/app/assets/stylesheets/common/foundation/helpers.scss
index 035f67c..e06dda7 100644
--- a/app/assets/stylesheets/common/foundation/helpers.scss
+++ b/app/assets/stylesheets/common/foundation/helpers.scss
@@ -22,7 +22,7 @@
 .hide,
 .hidden {
-  display: none;
+  display: none !important;
 .invisible {
GitHub sha: 5a34c7cc
This commit appears in #10640 which was approved by eviltrout. It was merged by eviltrout.
https://meta.discourse.org/t/guest-gate-sign-up-popup-plugin/56625/53
https://meta.discourse.org/t/your-topic-is-similar-to-box-has-class-hidden/97561/6
