FIX: adds shims for popper in wizard (#10658)
diff --git a/app/assets/javascripts/select-kit/addon/components/select-kit.js b/app/assets/javascripts/select-kit/addon/components/select-kit.js
index 34936ca..650fe22 100644
--- a/app/assets/javascripts/select-kit/addon/components/select-kit.js
+++ b/app/assets/javascripts/select-kit/addon/components/select-kit.js
@@ -1,3 +1,4 @@
+import { createPopper } from "@popperjs/core";
 import I18n from "I18n";
 import EmberObject, { computed, get } from "@ember/object";
 import { guidFor } from "@ember/object/internals";
@@ -772,8 +773,7 @@ export default Component.extend(
         const verticalOffset = this.multiSelect ? 0 : 3;
-        /* global Popper:true */
-        this.popper = Popper.createPopper(anchor, popper, {
+        this.popper = createPopper(anchor, popper, {
           eventsEnabled: false,
           strategy: placementStrategy,
           placement: this.selectKit.options.placement,
diff --git a/app/assets/javascripts/wizard-shims.js b/app/assets/javascripts/wizard-shims.js
new file mode 100644
index 0000000..d7bc171
--- /dev/null
+++ b/app/assets/javascripts/wizard-shims.js
@@ -0,0 +1,6 @@
+define("@popperjs/core", ["exports"], function (__exports__) {
+  __exports__.default = window.Popper;
+  __exports__.createPopper = window.Popper.createPopper;
+  __exports__.defaultModifiers = window.Popper.defaultModifiers;
+  __exports__.popperGenerator = window.Popper.popperGenerator;
diff --git a/app/assets/javascripts/wizard-vendor.js b/app/assets/javascripts/wizard-vendor.js
index f4e1d57..9b76a8f 100644
--- a/app/assets/javascripts/wizard-vendor.js
+++ b/app/assets/javascripts/wizard-vendor.js
@@ -4,4 +4,5 @@
 //= require sweetalert.js
 //= require virtual-dom
 //= require virtual-dom-amd
-//= require popper
+//= require popper.js
+//= require wizard-shims
GitHub sha: 9238a9e4
This commit appears in #10658 which was approved by CvX and eviltrout. It was merged by eviltrout.
