FIX: Allow CodeCommit-style theme .git url format (#12739)
diff --git a/app/assets/javascripts/admin/addon/controllers/modals/admin-install-theme.js b/app/assets/javascripts/admin/addon/controllers/modals/admin-install-theme.js
index de735c9..df91acd 100644
--- a/app/assets/javascripts/admin/addon/controllers/modals/admin-install-theme.js
+++ b/app/assets/javascripts/admin/addon/controllers/modals/admin-install-theme.js
@@ -24,7 +24,7 @@ export default Controller.extend(ModalFunctionality, {
   keyGenUrl: "/admin/themes/generate_key_pair",
   importUrl: "/admin/themes/import",
   recordType: "theme",
-  checkPrivate: match("uploadUrl", /^.*[@].*[:].*\.git$/),
+  checkPrivate: match("uploadUrl", /^ssh\:\/\/.*\@.*\.git$|.*\@.*\:.*\.git$/),
   localFile: null,
   uploadUrl: null,
   uploadName: null,
diff --git a/app/assets/javascripts/admin/addon/templates/modal/admin-install-theme.hbs b/app/assets/javascripts/admin/addon/templates/modal/admin-install-theme.hbs
index 5f09f33..2fda0a1 100644
--- a/app/assets/javascripts/admin/addon/templates/modal/admin-install-theme.hbs
+++ b/app/assets/javascripts/admin/addon/templates/modal/admin-install-theme.hbs
@@ -80,6 +80,10 @@
               <div class="label">{{i18n "admin.customize.theme.public_key"}}</div>
               {{textarea readonly=true value=publicKey}}
             </div>
+          {{else}}
+            {{#if privateChecked}}
+              <div class="public-key-note">{{i18n "admin.customize.theme.public_key_note"}}</div>
+            {{/if}}
           {{/if}}
         {{/if}}
       </div>
diff --git a/app/assets/javascripts/discourse/tests/acceptance/admin-install-theme-modal-test.js b/app/assets/javascripts/discourse/tests/acceptance/admin-install-theme-modal-test.js
index cee0b24..8c85c6e 100644
--- a/app/assets/javascripts/discourse/tests/acceptance/admin-install-theme-modal-test.js
+++ b/app/assets/javascripts/discourse/tests/acceptance/admin-install-theme-modal-test.js
@@ -67,8 +67,18 @@ acceptance("Admin - Themes - Install modal", function (needs) {
     assert.ok(query(publicKey), "shows public key");
+    // Supports AWS CodeCommit style repo URLs
+    await fillIn(
+      urlInput,
+      "ssh://someID@git-codecommit.us-west-2.amazonaws.com/v1/repos/test-repo.git"
+    assert.ok(query(publicKey), "shows public key");
     await fillIn(urlInput, "https://github.com/discourse/discourse.git");
-    assert.notOk(query(publicKey), "does not shows public key for https urls");
+    assert.notOk(query(publicKey), "does not show public key for https urls");
+    await fillIn(urlInput, "git@github.com:discourse/discourse.git");
+    assert.ok(query(publicKey), "shows public key for valid github repo url");
   test("modal can be auto-opened with the right query params", async function (assert) {
diff --git a/app/assets/stylesheets/common/admin/customize.scss b/app/assets/stylesheets/common/admin/customize.scss
index 5aad528..8fe711b 100644
--- a/app/assets/stylesheets/common/admin/customize.scss
+++ b/app/assets/stylesheets/common/admin/customize.scss
@@ -593,16 +593,19 @@
     width: auto;
     margin: 3px 0;
-  .public-key {
-    margin-top: 10px;
-    textarea {
-      cursor: auto;
-      height: 150px;
+.public-key {
+  margin-top: 1em;
+  textarea {
+    cursor: auto;
+    min-height: 220px;
+.public-key-note {
+  margin-top: 1em;
+  color: var(--primary-medium);
 // Permalinks
 .permalinks {
   .url,
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index 3b41ff7..66a61de 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -4265,6 +4265,7 @@ en:
           is_private: "Theme is in a private git repository"
           remote_branch: "Branch name (optional)"
           public_key: "Grant the following public key access to the repo:"
+          public_key_note: "After entering a valid private repository URL above, an SSH key will be generated and displayed here."
           install: "Install"
           installed: "Installed"
           install_popular: "Popular"
GitHub sha: 9581d713
This commit appears in #12739 which was approved by eviltrout. It was merged by pmusaraj.
