FIX: allow oneboxing for `www.amazon.com.mx`
FIX: allow oneboxing for www.amazon.com.mx
diff --git a/lib/onebox/engine/amazon_onebox.rb b/lib/onebox/engine/amazon_onebox.rb
index 25b726d..b2810af 100644
--- a/lib/onebox/engine/amazon_onebox.rb
+++ b/lib/onebox/engine/amazon_onebox.rb
@@ -11,7 +11,7 @@ module Onebox
       include HTML
       always_https
-      matches_regexp(/^https?:\/\/(?:www\.)?(?:smile\.)?(amazon|amzn)\.(?<tld>com|ca|de|it|es|fr|co\.jp|co\.uk|cn|in|com\.br)\//)
+      matches_regexp(/^https?:\/\/(?:www\.)?(?:smile\.)?(amazon|amzn)\.(?<tld>com|ca|de|it|es|fr|co\.jp|co\.uk|cn|in|com\.br|com\.mx)\//)
       def url
         if match && match[:id]
diff --git a/spec/lib/onebox/engine/amazon_onebox_spec.rb b/spec/lib/onebox/engine/amazon_onebox_spec.rb
index 5b49b34..809acdf 100644
--- a/spec/lib/onebox/engine/amazon_onebox_spec.rb
+++ b/spec/lib/onebox/engine/amazon_onebox_spec.rb
@@ -60,6 +60,9 @@ describe Onebox::Engine::AmazonOnebox do
         check_link("in", "https://www.amazon.in/Fireflies-Rabindranath-Tagore/dp/9381523169/")
+      it "matches mexican domains" do
+        check_link("com.mx", "https://www.amazon.com.mx/Legend-Zelda-Links-Awakening-Nintendo/dp/B07SG15148/")
+      end
     describe "#url" do
GitHub sha: e0eaaec2
