FIX: allow specifying platform name for platform specific gems (PR #10559)
Discussed here: https://meta.discourse.org/t/facing-an-issue-while-installing-some-gems-in-the-plugin/161780
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
https://meta.discourse.org/t/facing-an-issue-while-installing-some-gems-in-the-plugin/161780/9
OK seems like a reasonable workaround, should not impact any existing plugins.
