FIX: Allow themes to upload and serve js files (#8188)
If you set config.public_file_server.enabled = false when you try to get uploaded js file you will get an error: Security warning: an embedded <script> tag on another site requested protected JavaScript. If you know what you're doing, go ahead and disable forgery protection on this action to permit cross-origin JavaScript embedding.
The reason is that content type is application/javascript and in Rails 5 guard looked like that: rails/request_forgery_protection.rb at 5-2-stable · rails/rails · GitHub However, in Rails 6 application was added to regex: rails/request_forgery_protection.rb at master · rails/rails · GitHub
This pull request is related to Uploaded .js file for theme causes a rejection? - support - Discourse Meta
diff --git a/app/controllers/uploads_controller.rb b/app/controllers/uploads_controller.rb
index 78c1623704..78fd13c8eb 100644
--- a/app/controllers/uploads_controller.rb
+++ b/app/controllers/uploads_controller.rb
@@ -6,6 +6,7 @@ class UploadsController < ApplicationController
   requires_login except: [:show, :show_short]
   skip_before_action :preload_json, :check_xhr, :redirect_to_login_if_required, only: [:show, :show_short]
+  protect_from_forgery except: :show
   def create
     # capture current user for block later on
diff --git a/spec/fixtures/themes/test.js b/spec/fixtures/themes/test.js
new file mode 100644
index 0000000000..14c198cadb
--- /dev/null
+++ b/spec/fixtures/themes/test.js
@@ -0,0 +1 @@
+console.log("test");
diff --git a/spec/requests/uploads_controller_spec.rb b/spec/requests/uploads_controller_spec.rb
index d779898e5f..cb738c73ea 100644
--- a/spec/requests/uploads_controller_spec.rb
+++ b/spec/requests/uploads_controller_spec.rb
@@ -265,6 +265,13 @@ describe UploadsController do
         .to eq(%Q|attachment; filename="logo.png"; filename*=UTF-8''logo.png|)
+    it 'returns 200 when js file' do
+      ActionDispatch::FileHandler.any_instance.stubs(:match?).returns(false)
+      upload = upload_file("test.js", "themes")
+      get upload.url
+      expect(response.status).to eq(200)
+    end
     it "handles image without extension" do
       SiteSetting.authorized_extensions = "*"
       upload = upload_file("image_no_extension")
GitHub sha: 99086edf
rogue commit ;p
Can we do this thing without that stub?
Writing a test for that stuff was harder than I expected. Let me walk you through what is happening:
In environments/test.rb we got config.public_file_server.enabled = true
When that is set to true, ActionDispatch::Static middleware is added:
if config.public_file_server.enabled
  headers = config.public_file_server.headers || {}
  middleware.use ::ActionDispatch::Static, paths["public"].first, index:
  config.public_file_server.index_name, headers: headers
This middleware https://api.rubyonrails.org/classes/ActionDispatch/Static.html#method-i-call is a shortcut to serve the file directly from disk and it skips protect from forgery, so the test is passing with and without fix.
So to test the fix, I thought about 2 options:
  1. Change the flag in environments/test.rb to be false. The benefit is that false is the default for production so it makes some sense. I checked that on my local machine tests are equally performant, however, I wasn’t sure if I want to change that flag for the whole test suite.
  2. I decided to stub the method used in ActionDispatch::Static middleware, to skip shortcut and move forward through rake stack.
What is your recommendation here?
I kind of like this option, having better parity with production makes me happy. If perf is identical for the test suite go ahead and change that.
Sorry, I needed to revert that change Revert "FIX: public_file_server.enabled is false in test" by lis2 · Pull Request #8196 · discourse/discourse · GitHub
My bad that I checked only rspec, didn’t run qunit and beside failing, that change was making it terrible slow
Tags are a little bit more complicated than categories because the topic can have multiple tags. We need to make a decision about what to do in the case when we got two tags tag_a and tag_b.
Let’s say I mute tag_a and the new post is arriving with both tags.
Should we mark that post as new and display in the latest section?
I think that yes and we should hide it only if both tags are muted, but that is making the solution more complex and I am not sure if that is worth.
An easier option would be to just skip any topic if any of the tags is muted
Feels like the wrong topic to me :slight_smile:
I think if there is a message that there is a new topic, and you have the tag muted, no matter what the “1 new or updated topics” thing should not show up.
As to what happens in the list … that is a bit more complex.
TopicTrackingState query though is a more complicated problem, we don’t want to add cost there :frowning:
