FIX: allow upload recovery to recover uploads with sha mismatch
Filename on disk may mismatch sha of file in some old 1X setups. This will attempt to recover file even if sha1 mismatches. We had an old bug that caused this.
This also adds uploads:fix_relative_upload_links which attempts to replace urls of the format /upload/default/... with upload://
diff --git a/lib/tasks/uploads.rake b/lib/tasks/uploads.rake
index a6744f2..8619991 100644
--- a/lib/tasks/uploads.rake
+++ b/lib/tasks/uploads.rake
@@ -886,3 +886,36 @@ task "uploads:recover" => :environment do
+def inline_uploads(post)
+  replaced = false
+  original_raw = post.raw
+  post.raw = post.raw.gsub(/(\((\/uploads\S+).*\))/) do
+    upload = Upload.find_by(url: $2)
+    result = $1
+    if upload&.id
+      result.sub!($2, upload.short_url)
+      replaced = true
+    else
+      puts "Upload not found #{$2} in Post #{post.id} - #{post.url}"
+    end
+    result
+  end
+  if replaced
+    puts "Corrected image urls in #{post.url} raw backup stored in custom field"
+    post.custom_fields["BACKUP_POST_RAW"] = original_raw
+    post.save_custom_fields
+    post.save!
+    post.rebake!
+  end
+end
+task "uploads:fix_relative_upload_links" => :environment do
+  Post.where('raw like ?', '%](/uploads%').find_each do |post|
+    inline_uploads(post)
+  end
+end
diff --git a/lib/upload_recovery.rb b/lib/upload_recovery.rb
index a4d0433..136fbfd 100644
--- a/lib/upload_recovery.rb
+++ b/lib/upload_recovery.rb
@@ -63,15 +63,27 @@ class UploadRecovery
+  def ensure_upload!(post:, sha1:, upload:)
+    return if !upload.persisted?
+    if upload.sha1 != sha1
+      STDERR.puts "Warning #{post.url} had an incorrect sha, remapping #{sha1} to #{upload.sha1}"
+      post.raw = post.raw.gsub(sha1, upload.sha1)
+      post.save!
+    end
+    post.rebake!
+  end
   def recover_post_upload_from_local(post:, sha1:)
     recover_from_local(sha1: sha1, user_id: post.user_id) do |upload|
-      post.rebake! if upload.persisted?
+      ensure_upload!(post: post, sha1: sha1, upload: upload)
   def recover_post_upload_from_s3(post:, sha1:)
     recover_from_s3(sha1: sha1, user_id: post.user_id) do |upload|
GitHub sha: ebcb571d
It’ll be good if we can update the specs for this change as well. discourse/upload_recovery_spec.rb at master · discourse/discourse · GitHub
