FIX: allows adapters to define a custom primaryKey (#9254)
diff --git a/app/assets/javascripts/discourse/adapters/rest.js b/app/assets/javascripts/discourse/adapters/rest.js
index e92f325..a228791 100644
--- a/app/assets/javascripts/discourse/adapters/rest.js
+++ b/app/assets/javascripts/discourse/adapters/rest.js
@@ -27,6 +27,8 @@ function rethrow(error) {
 export default EmberObject.extend({
+  primaryKey: "id",
   storageKey(type, findArgs, options) {
     if (options && options.cacheKey) {
       return options.cacheKey;
@@ -132,7 +134,7 @@ export default EmberObject.extend({
   destroyRecord(store, type, record) {
-    return ajax(this.pathFor(store, type, record.get("id")), {
+    return ajax(this.pathFor(store, type, record.get(this.primaryKey)), {
       type: "DELETE"
diff --git a/app/assets/javascripts/discourse/models/store.js b/app/assets/javascripts/discourse/models/store.js
index 1bc9fdf..9444116 100644
--- a/app/assets/javascripts/discourse/models/store.js
+++ b/app/assets/javascripts/discourse/models/store.js
@@ -124,14 +124,14 @@ export default EmberObject.extend({
       if (adapter.cache) {
         const stale = adapter.findStale(this, type, findArgs, opts);
-        hydrated = this._updateStale(stale, hydrated);
+        hydrated = this._updateStale(stale, hydrated, adapter.primaryKey);
         adapter.cacheFind(this, type, findArgs, opts, hydrated);
       return hydrated;
-  _updateStale(stale, hydrated) {
+  _updateStale(stale, hydrated, primaryKey) {
     if (!stale) {
       return hydrated;
@@ -139,7 +139,7 @@ export default EmberObject.extend({
     hydrated.set(
       "content",
       hydrated.get("content").map(item => {
-        var staleItem = stale.content.findBy("id", item.get("id"));
+        var staleItem = stale.content.findBy(primaryKey, item.get(primaryKey));
         if (staleItem) {
           staleItem.setProperties(item);
         } else {
@@ -186,12 +186,11 @@ export default EmberObject.extend({
   update(type, id, attrs) {
-    return this.adapterFor(type).update(this, type, id, attrs, function(
-      result
-      if (result && result[type] && result[type].id) {
+    const adapter = this.adapterFor(type);
+    return adapter.update(this, type, id, attrs, function(result) {
+      if (result && result[type] && result[type][adapter.primaryKey]) {
         const oldRecord = findAndRemoveMap(type, id);
-        storeMap(type, result[type].id, oldRecord);
+        storeMap(type, result[type][adapter.primaryKey], oldRecord);
       return result;
@@ -199,22 +198,25 @@ export default EmberObject.extend({
   createRecord(type, attrs) {
     attrs = attrs || {};
-    return !!attrs.id ? this._hydrate(type, attrs) : this._build(type, attrs);
+    return !!attrs[adapter.primaryKey]
+      ? this._hydrate(type, attrs)
+      : this._build(type, attrs);
   destroyRecord(type, record) {
     // If the record is new, don't perform an Ajax call
     if (record.get("isNew")) {
-      removeMap(type, record.get("id"));
+      removeMap(type, record.get(adapter.primaryKey));
       return Promise.resolve(true);
-      .destroyRecord(this, type, record)
-      .then(function(result) {
-        return result;
+    return adapter.destroyRecord(this, type, record).then(function(result) {
+      return result;
   _resultSet(type, result, findArgs) {
@@ -252,9 +254,10 @@ export default EmberObject.extend({
   _build(type, obj) {
     obj.store = this;
     obj.__type = type;
-    obj.__state = obj.id ? "created" : "new";
+    obj.__state = obj[adapter.primaryKey] ? "created" : "new";
     // TODO: Have injections be automatic
     obj.topicTrackingState = this.register.lookup("topic-tracking-state:main");
@@ -264,7 +267,7 @@ export default EmberObject.extend({
     const klass = this.register.lookupFactory("model:" + type) || RestModel;
     const model = klass.create(obj);
-    storeMap(type, obj.id, model);
+    storeMap(type, obj[adapter.primaryKey], model);
     return model;
@@ -288,6 +291,7 @@ export default EmberObject.extend({
       subType = root.meta.types[subType] || subType;
+    const subTypeAdapter = this.adapterFor(subType);
     const pluralType = this.pluralize(subType);
     const collection = root[this.pluralize(subType)];
     if (collection) {
@@ -296,7 +300,7 @@ export default EmberObject.extend({
       if (!hashedCollection) {
         hashedCollection = {};
         collection.forEach(function(it) {
-          hashedCollection[it.id] = it;
+          hashedCollection[it[subTypeAdapter.primaryKey]] = it;
         root[hashedProp] = hashedCollection;
@@ -311,7 +315,12 @@ export default EmberObject.extend({
   _hydrateEmbedded(type, obj, root) {
     Object.keys(obj).forEach(k => {
+      if (k === adapter.primaryKey) {
+        return;
       const m = /(.+)\_id(s?)$/.exec(k);
       if (m) {
         const subType = m[1];
@@ -340,9 +349,13 @@ export default EmberObject.extend({
       throw new Error("Can't hydrate " + type + " of `null`");
-    const id = obj.id;
+    const id = obj[adapter.primaryKey];
     if (!id) {
-      throw new Error("Can't hydrate " + type + " without an `id`");
+      throw new Error(
+        `Can't hydrate ${type} without primaryKey: \`${adapter.primaryKey}\``
     root = root || obj;
@@ -357,7 +370,7 @@ export default EmberObject.extend({
     if (existing) {
-      delete obj.id;
+      delete obj[adapter.primaryKey];
       let klass = this.register.lookupFactory("model:" + type);
       if (klass && klass.class) {
@@ -369,7 +382,7 @@ export default EmberObject.extend({
       existing.setProperties(klass.munge(obj));
-      obj.id = id;
+      obj[adapter.primaryKey] = id;
       return existing;
diff --git a/test/javascripts/helpers/create-store.js b/test/javascripts/helpers/create-store.js
index 8eccc0d..5385a48 100644
--- a/test/javascripts/helpers/create-store.js
+++ b/test/javascripts/helpers/create-store.js
@@ -5,12 +5,21 @@ import TopicListAdapter from "discourse/adapters/topic-list";
 import TopicTrackingState from "discourse/models/topic-tracking-state";
 import { buildResolver } from "discourse-common/resolver";
+const CatAdapter = RestAdapter.extend({
+  primaryKey: "cat_id"
 export default function(customLookup = () => {}) {
   const resolver = buildResolver("discourse").create();
   return Store.create({
     register: {
       lookup(type) {
+        if (type === "adapter:cat") {
+          this._catAdapter =
+            this._catAdapter || CatAdapter.create({ owner: this });
+          return this._catAdapter;
         if (type === "adapter:rest") {
           if (!this._restAdapter) {
             this._restAdapter = RestAdapter.create({ owner: this });
diff --git a/test/javascripts/helpers/store-pretender.js b/test/javascripts/helpers/store-pretender.js
index 30be564..1579aba 100644
--- a/test/javascripts/helpers/store-pretender.js
+++ b/test/javascripts/helpers/store-pretender.js
@@ -26,9 +26,23 @@ const colors = [
   { id: 3, name: "Yellow" }
+const cats = [
+    cat_id: 1,
+    name: "souna"
 export default function(helpers) {
   const { response, success, parsePostData } = helpers;
+  this.get("/cats", function() {
+    return response({
+      __rest_serializer: "1",
+      cats
   this.get("/fruits/:id", function(request) {
     const fruit = fruits.find(f => f.id === parseInt(request.params.id, 10));
GitHub sha: 2b78bd01
This commit appears in #9254 which was approved by eviltrout. It was merged by jjaffeux.
