FIX: allows adapters to define a custom primaryKey (PR #9254)
GitHub
It seems fine to me, but I am curious what the motivation for the change is? In what situation is id not available?
rails allows you to override primary_key of a model. And it has bitten me multiple times last year, and I just decided to fix it :stuck_out_tongue:
I’m about to write an article about using store instead if ajax as many people don’t use store, and I want to reduce at the minimum the limitations of using store.
