FIX: allows custom groups updates to be reflected without recompilation (#9421)
diff --git a/app/assets/javascripts/discourse/components/emoji-picker.js b/app/assets/javascripts/discourse/components/emoji-picker.js
index ef56c41..88b7599 100644
--- a/app/assets/javascripts/discourse/components/emoji-picker.js
+++ b/app/assets/javascripts/discourse/components/emoji-picker.js
@@ -1,4 +1,5 @@
 import { inject as service } from "@ember/service";
+import { schedule } from "@ember/runloop";
 import Component from "@ember/component";
 import { on, observes } from "discourse-common/utils/decorators";
 import { findRawTemplate } from "discourse/lib/raw-templates";
@@ -16,23 +17,16 @@ const { run } = Ember;
 const PER_ROW = 11;
 function customEmojis() {
   const list = extendedEmojiList();
-  const emojis = Object.keys(list)
-    .map(code => {
-      const { group } = list[code];
-      return {
-        code,
-        src: emojiUrlFor(code),
-        group,
-        key: `emoji_picker.${group || "default"}`
-    .reduce((acc, curr) => {
-      if (!acc[curr.group]) acc[curr.group] = [];
-      acc[curr.group].push(curr);
-      return acc;
-  return Object.values(emojis);
+  const groups = [];
+  Object.keys(list).forEach(code => {
+    const emoji = list[code];
+    groups[emoji.group] = groups[emoji.group] || [];
+    groups[emoji.group].push({
+      code,
+      src: emojiUrlFor(code)
+  return groups;
 export default Component.extend({
@@ -42,9 +36,8 @@ export default Component.extend({
   close() {
     this._unbindEvents();
-    this.$picker
-      .css({ width: "", left: "", bottom: "", display: "none" })
-      .empty();
+    this.$picker &&
+      this.$picker.css({ width: "", left: "", bottom: "", display: "none" });
     this.$modal.removeClass("fadeIn");
@@ -52,11 +45,6 @@ export default Component.extend({
   show() {
-    const template = findRawTemplate("emoji-picker")({
-      customEmojis: customEmojis()
-    this.$picker.html(template);
     this.$filter = this.$picker.find(".filter");
     this.$results = this.$picker.find(".results");
     this.$list = this.$picker.find(".list");
@@ -84,6 +72,7 @@ export default Component.extend({
   @on("init")
   _setInitialValues() {
+    this.set("customEmojis", customEmojis());
     this._checkTimeout = null;
     this.scrollPosition = 0;
     this.$visibleSections = [];
@@ -100,14 +89,21 @@ export default Component.extend({
   @on("didInsertElement")
   _setup() {
-    this.$picker = $(this.element.querySelector(".emoji-picker"));
-    this.$modal = $(this.element.querySelector(".emoji-picker-modal"));
     this.appEvents.on("emoji-picker:close", this, "_closeEmojiPicker");
   @on("didUpdateAttrs")
   _setState() {
-    this.active ? this.show() : this.close();
+    schedule("afterRender", () => {
+      if (!this.element) {
+        return;
+      this.$picker = $(this.element.querySelector(".emoji-picker"));
+      this.$modal = $(this.element.querySelector(".emoji-picker-modal"));
+      this.active ? this.show() : this.close();
   @observes("filter")
diff --git a/app/assets/javascripts/discourse/templates/components/emoji-picker.hbs b/app/assets/javascripts/discourse/templates/components/emoji-picker.hbs
deleted file mode 100644
index 7f7490e..0000000
--- a/app/assets/javascripts/discourse/templates/components/emoji-picker.hbs
+++ /dev/null
@@ -1,2 +0,0 @@
-<div class="emoji-picker"></div>
-<div class="emoji-picker-modal"></div>
diff --git a/app/assets/javascripts/discourse/templates/components/emoji-picker.hbs.erb b/app/assets/javascripts/discourse/templates/components/emoji-picker.hbs.erb
new file mode 100644
index 0000000..f3504d3
--- /dev/null
+++ b/app/assets/javascripts/discourse/templates/components/emoji-picker.hbs.erb
@@ -0,0 +1,88 @@
+<div class="emoji-picker">
+  {{#if active}}
+    <div class='categories-column'>
+      <div class='category-icon'>
+        <button type="button" class="emoji" tabindex="-1" title="{{i18n 'emoji_picker.recent'}}" data-section="recent" data-tabicon="star"></button>
+      </div>
+      <% JSON.parse(File.read("lib/emoji/groups.json")).each.with_index do |group, group_index| %>
+        <button type="button" class="emoji" tabindex="-1" data-tabicon="<%= group["tabicon"] %>" data-section="<%= group["name"] %>" title="{{i18n '<%= "emoji_picker.#{group["name"]}" %>'}}"></button>
+        </div>
+      <% end %>
+      {{#each-in customEmojis as |group emojis|}}
+          <button data-tabicon={{emojis.firstObject.code}} type="button" class="emoji" tabindex="-1" data-section="custom-{{group}}" title="{{i18n (concat 'emoji_picker.' group)}}"></button>
+        </div>
+      {{/each-in}}
+    </div>
+    <div class='main-column'>
+      <div class='filter'>
+        {{d-icon 'search'}}
+        <input type='text' name="filter" placeholder="{{i18n 'emoji_picker.filter_placeholder'}}" autocomplete="discourse"/>
+        <button class='clear-filter'>
+          {{d-icon 'times'}}
+        </button>
+      </div>
+      <div class='results'></div>
+      <div class='list'>
+        <div class='section' data-section='recent'>
+          <div class='section-header'>
+            <span class="title">{{i18n 'emoji_picker.recent'}}</span>
+            <a href='#' class='clear-recent'>{{d-icon "trash-alt"}}</a>
+          </div>
+          <div class='section-group'></div>
+        </div>
+          <div class='section' data-section='<%= group["name"] %>'>
+              <span class="title">{{i18n 'emoji_picker.<%= group["name"] %>'}}</span>
+            </div>
+              <% group["icons"].each  do |icon| %>
+                <button type="button" class="emoji <%= "diversity" if icon["diversity"] %>" tabindex="-1" title="<%= icon['name']%>"></button>
+              <% end %>
+            </div>
+          </div>
+        <% end %>
+          <div class='section' data-section='custom-{{group}}'>
+                {{i18n (concat 'emoji_picker.' group)}}
+              </span>
+            </div>
+            {{#if emojis.length}}
+                {{#each emojis as |emoji|}}
+                  <button type="button" class="emoji" tabindex="-1" title=":{{emoji.code}}:">
+                    <img loading="lazy" class="emoji" src="{{emoji.src}}">
+                  </button>
+                {{/each}}
+              </div>
+            {{/if}}
+          </div>
+        {{/each-in}}
+      </div>
+      <div class='footer'>
+        <div class='info'></div>
+        <div class='diversity-picker'>
+          <% ['default', 'light', 'medium-light', 'medium', 'medium-dark', 'dark'].each.with_index do |diversity, index| %>
+            <a href='#' title="{{i18n 'emoji_picker.<%= diversity.gsub('-', '_') %>_tone'}}" class='diversity-scale <%= diversity %>' data-level="<%= index + 1 %>">
+              {{d-icon "check"}}
+            </a>
+          <% end %>
+        </div>
+      </div>
+    </div>
+  {{/if}}
+</div>
+<div class="emoji-picker-modal"></div>
diff --git a/app/assets/javascripts/discourse/templates/emoji-picker.hbr.erb b/app/assets/javascripts/discourse/templates/emoji-picker.hbr.erb
index 5a33352..0000000
--- a/app/assets/javascripts/discourse/templates/emoji-picker.hbr.erb
+++ /dev/null
@@ -1,81 +0,0 @@
-<div class='categories-column'>
-  <div class='category-icon'>
-    <button type="button" class="emoji" tabindex="-1" title="{{i18n 'emoji_picker.recent'}}" data-section="recent" data-tabicon="star"></button>
-  </div>
GitHub sha: d9db0e66
This commit appears in #9421 which was approved by eviltrout. It was merged by jjaffeux.
