FIX: allows to remove a topic timer with delete_replies as type (#9800)
diff --git a/app/controllers/topics_controller.rb b/app/controllers/topics_controller.rb
index 954369a..211e94c 100644
--- a/app/controllers/topics_controller.rb
+++ b/app/controllers/topics_controller.rb
@@ -445,7 +445,7 @@ class TopicsController < ApplicationController
         invalid_param(:status_type)
     based_on_last_post = params[:based_on_last_post]
-    params.require(:duration) if based_on_last_post || TopicTimer.types[:delete_replies] == status_type
+    params.require(:duration) if based_on_last_post
     topic = Topic.find_by(id: params[:topic_id])
     guardian.ensure_can_moderate!(topic)
diff --git a/spec/requests/topics_controller_spec.rb b/spec/requests/topics_controller_spec.rb
index cf4f5f1..726b922 100644
--- a/spec/requests/topics_controller_spec.rb
+++ b/spec/requests/topics_controller_spec.rb
@@ -2709,6 +2709,24 @@ RSpec.describe TopicsController do
         expect(json['duration']).to eq(topic_status_update.duration)
+      it 'should be able to delete a topic status update for delete_replies type' do
+        Fabricate(:topic_timer, topic: topic, status_type: TopicTimer.types[:delete_replies])
+        post "/t/#{topic.id}/timer.json", params: {
+          time: nil,
+          status_type: TopicTimer.types[7]
+        expect(response.status).to eq(200)
+        expect(topic.reload.public_topic_timer).to eq(nil)
+        json = response.parsed_body
+        expect(json['execute_at']).to eq(nil)
+        expect(json['duration']).to eq(nil)
+        expect(json['closed']).to eq(topic.closed)
+      end
       describe 'publishing topic to category in the future' do
         it 'should be able to create the topic status update' do
GitHub sha: 918bd759
This commit appears in #9800 which was approved by vinothkannans. It was merged by jjaffeux.
